9973720wb19
Your 4720 wheels would be to large for his 4300.
Oh, Okay...thanks.
Woody65. I have Standard R4 tires and rims off my 4720 Cab they have about 150 hrs on them - let me know if you're interested in them. I switched to R1s for snow and mud reasons. I don't know how I'd get them to NY from MD though.
I would immediately consult your dealer on this before the problem causes some other item to be damaged. I don't believe your use of full time 4 WD while on pasture or dirt would damage the running gear and as you say you are in constant hilly terrain which could be unsafe if not in 4 WD. It might cause some premature wear and for sure wears the front tires faster but it shouldn't cause your transmission to lock up. I think there is more likely a problem in the HST transmission. Damaged gears in the front axle wouldn't cause your HST pedal to jump back up and lock up the tractor.
