Ford 1500 Rear Hydraulics
   / Ford 1500 Rear Hydraulics #1
9055
Louisa
Ford 1500
Hello Tractor people
I have an 1980 Ford 1500 tractor and i'm having some three point hitch lift problems, when i start up and lift attachments and in the the lock bracket on my right side lever position, it squeals, so i adjusted the lock bracket down until it quit making noise and i continued to lift and lower my blade it started squealing again and was not raising the blade that quick, it got slower and slower and squealing until i finally took it back to the barn and parked it, but this morning i cranked it back up and it raised the blade quick and was not making any racket until i had the lever all the way up past the lock bracket! ANY SUGGESTIONS?
   / Ford 1500 Rear Hydraulics #2
Welcome to the forum!
:welcome:
I'm moving your thread over to the vintage Ford section to see if we can get you some answers. You might also consider posting in the hydraulics section.
   / Ford 1500 Rear Hydraulics #3
You're not supposed to raise it up into the lock area. I was told that is for service only. If you have to raise it that far something is out of adjustment.
I think i have found or know whats going on with it,most of the squealing is coming from the back of the tractor and seems to get worse as the fluid is heating up and making the lift slower, so i'm guessing the lift piston needs rings,and when i had the blade raised and shut the tractor down it dropped pretty quick, so i hope that's the problem,and for the lock for the lever in the up position i thought that was for when you were tramming with hitch up with what ever attachment you have on!
   / Ford 1500 Rear Hydraulics #5
What that position does is bypass the position control valve sending full pressure to the lift. Not good for the piston seal. I would use it only in emergency to get back to the shop or something.
NAPA 230V AIR COMPRESSOR (A53843)
NAPA 230V AIR...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A54607)
2007 FREIGHTLINER...
2018 KENWORTH T800 (A53843)
2018 KENWORTH T800...
Adams 5 T Spreader (A55301)
Adams 5 T Spreader...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
