Ford 1700 lift problem (yes again)
   / Ford 1700 lift problem (yes again)
So here is the latest update.
Took apart the spool valve and checked for dirt. none found and oring looked good
Jacked up the back of the tractor to make sure its getting oil and that the pump is primed
Removed the little arm from the lift lever as book instructed as tried full up with gauge attached. never saw over 650-700 psi.
the pressure was never constant and would go back to 0. hyd. still noisy and sounds like it straining. the only thing I have not done is remove the lift cylinder and inspect it.
Will be doing that soon, if nothing is found there it will be a pump replacement next.
Any thought from experts would be nice
Thanks
   / Ford 1700 lift problem (yes again) #12
So here is the latest update. Took apart the spool valve and checked for dirt. none found and oring looked good Jacked up the back of the tractor to make sure its getting oil and that the pump is primed Removed the little arm from the lift lever as book instructed as tried full up with gauge attached. never saw over 650-700 psi. the pressure was never constant and would go back to 0. hyd. still noisy and sounds like it straining. the only thing I have not done is remove the lift cylinder and inspect it. Will be doing that soon, if nothing is found there it will be a pump replacement next. Any thought from experts would be nice Thanks
Have you cleaned the screen for the hydrolics yet. There is no filter, just a metal screen. Sounds like it is clogged to me.
Yes a long time ago in the trouble shooting process
   / Ford 1700 lift problem (yes again) #14
650-700 is not near enough pressure. Pump may be going or did you service the filter? I know it's a screen, but Shibaura and the service manual call it a filter.
   / Ford 1700 lift problem (yes again) #15
When I had my 1700 I had to clean the screen on a yearly basis. I take it you changed the fluid when you cleaned the screen. Sounds like pump problems or there is a clog somewhere.
2017 CATERPILLAR 307E2 EXCAVATOR (A51246)
2017 CATERPILLAR...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2025 Mower King SSBM72 (A50123)
2025 Mower King...
UNUSED GOLD MOUNTAIN M122009 12'X20' STEEL CARPORT (A51248)
UNUSED GOLD...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
