2014 KIOTI DK55 Good Deal?
   / 2014 KIOTI DK55 Good Deal? #21
I know a member here (Eric the Oracle) pulls his NX6010 Cab HST with all features, loaded tires, and brushhog with his F150 up and down MN, I think the total is about 10,000lbs. Unless your 250 has major problems, I wouldn't worry about it. I wouldn't hesitate to haul it with my suburban, which I believe has less capacity then your truck.
On slopes it downshifts to 5th, on hills it downshifts to 4th gear.
   / 2014 KIOTI DK55 Good Deal? #22
YIKES,good luck stopping that load running 80mph.To each his own..
   / 2014 KIOTI DK55 Good Deal? #24
I have a 2006 ford F-150 super crew 4X4 with a 20 ft PJ bumper 7,000 axles (brakes on both axles ).Pulling my 2012 Kioti DK40 se(cab) KL401 loader with my 6ft.bush hog it takes sometime to get her stopped as in it will NOT stop fast.Towing specs and getting the weight stopped are two different comparsions.Good luck to you..
   / 2014 KIOTI DK55 Good Deal? #25
In 2009 the brakes were significantly upgraded as F150 towing anywhere near their rating warped brake rotors. In 2012, the front brakes were upped again in response to ecoboost owners towing heavier loads. My truck has just over 70,000 miles and the brakes are just under halfway worn out as per my own inspection two weeks ago.
   / 2014 KIOTI DK55 Good Deal? #26
Good information,thanks..
Well, finally got her home! Went through Uship, awesome experience and very reasonable cost.
This is like driving a Cadillac compared to my Fordson. It has brakes and you can start with the turn of a key!
Now on to attachments and implements...
   / 2014 KIOTI DK55 Good Deal? #28
   / 2014 KIOTI DK55 Good Deal? #29
Looks good, and on the plus side, you don't have to put a 4x4 in front of the front tires to keep it from rolling off downhill:laughing:
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
KUBOTA SKID STEER (A52707)
KUBOTA SKID STEER...
2020 Kinze 3505 High Speed 6/11 Planter (A55314)
2020 Kinze 3505...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2014 Ford F-150 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
