New garage, but it's too hot to work in it.
   / New garage, but it's too hot to work in it. #21
Are you guys insulating directly below the roof? I.e fiberglass between the joists and right against the roof plywood? If so I may try that in my 30x50 garage, it has a full attic and putting insulation on the floor would cost me the storage space.
   / New garage, but it's too hot to work in it. #22
In my opinion, whatever that's worth, I think insulation at the ceiling, leaving the air gap between the rafters/ceiling, would add some R factor. Additionally, you minimize the cubic feet of space being heated.
In my case my building is all metal and there's no air gap between my roof tin and the interior ceiling tin. Works for me. :)
   / New garage, but it's too hot to work in it. #23
You can do that, but you need to put foam baffle (channel) in there to allow airflow from eaves up to the ridge. Normally it's only done for cathedral ceilings.
There is another technique where spray foam is shot on the underside of the roof, but I don't know what they do about ventilation. Spray foam changes the dynamics of things, even on walls, so there may be a different way to handle ventilation. Maybe someone else knows. I bet Eddie Walker knows if he swings by this thread.
   / New garage, but it's too hot to work in it. #24
It's my understanding that if you use closed cell foam it can be sprayed directly to the under side of the roof with no concern for ventilation as is a vapor barrier and there's no concern of moisture to cause condensation on the under side of the roof.
   / New garage, but it's too hot to work in it. #25
   / New garage, but it's too hot to work in it. #26
I would put 3" of closed cell foam in the roof. It you plan to leave it exposed, I would also paint it white. This will add UV protection and brighten up your work area.
Ditto on the closed cell foam insulation. Re insulated my shop two years ago with foam. Yeasty warm in the winter and significantly cooler in the summer.
B John
   / New garage, but it's too hot to work in it. #27
B John
Yes sir, it's good stuff. It's amazing the difference that foam (closed or open) can made.
   / New garage, but it's too hot to work in it. #28
B John
   / New garage, but it's too hot to work in it. #29
Foam makes a perfect gasket between all the members it's shot over. The best vapor barrier you can get. That's part of why it's so effective. No air can get through.
   / New garage, but it's too hot to work in it. #30
I have this in one of my buildings and I agree it's easy to install and does seem to work good. I was pleased with it for the first few years, but now I'm not and wouldn't recommend it.
After 5 or 6 years it started falling apart. The white backing material cracks/flakes off in little round circles (same size as the bubbles) and it looks bad. It's a never ending battle trying to keep it cleaned up.
There are several areas were it has started to pull apart and sag. I have also noticed that many of the bubbles have busted and I doubt it has much value any more.
I'm going to cut it out and replace it with foam.
Uh-oh! Mines only been up two years. I put prodex under the roof (not double bubble, but a foam sandwiched between foils) and infrastop (double bubble foil sandwich) on the walls. Do you recall what product you used?
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2008 AAR MOBILITY SYSTEMS REFRIGERATED CONTAINER (A54607)
2008 AAR MOBILITY...
