Who makes the highest quality PTO generator?
   / Who makes the highest quality PTO generator? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
   / Who makes the highest quality PTO generator? #2
Winco....lol
I had one a couple years back but installed a 17KW generac and sold it. Too much hassle for the wife. Automatic switching and startup is easier for her. You want a 540 input rpm, not a 515. You smaller engine is designed to be most efficient at 540 pto output speed.
   / Who makes the highest quality PTO generator? #3
Nothing wrong with the Winco brand, it's considered to be a VERY good brand of PTO gen set...
SR
   / Who makes the highest quality PTO generator? #4
I've always heard good things about Winco.
Winco....lol
An old thread here mentioned --I think--that the Winco had a gauge on it to tell when it was operating at 515 rpm. Seems it wasn't much different of an engine speed than 540. It doesn't seem like that would be a big issue? Winco must not think so either?
   / Who makes the highest quality PTO generator? #6
Winco is a really good name--well established--50+ years doing gensets (had a '62 at work). It was the first name I thought of reading your title.
   / Who makes the highest quality PTO generator? #7
First of all I'm biased, I've a Winco 12KW. Paid $600, almost brand new, off CL. http://www.tractorbynet.com/forums/attachments/247124-winco-12ptoc-3-b-12kw.html
I'm finally ready to buy a PTO generator and figure if I buy the best it will save a lot of hassle later on. I'm thinking 15K and I had planned to buy a Winco only because I know the name and haven't heard anything bad about them. Is that a respected brand? Any other names come to mind?
Winco W15PTOS PTO Generator (15kW)
Winco W15PTOS PTO Generator, Shaft, & Trailer Package (15kW)
Look through the old threads, VERY well respected.
Winco....lol
How well does your Generac perform out in the field? Is it on a trailer? Do you tow your wife out with it? If the OP is looking at a kit WITH TRAILER he might be thinking of MOVING it around.
My Winco has a gauge to tell me when it's operating within range.
Before I bought mine I spent months, if not years, searching CL. They turn up on occasion in EXCELLENT condition because people like 5030 bought the wrong thing in the first place. If you need something for a fixed place w/ automatic transfer switches etc. a PTO generator may not be your best bet.
   / Who makes the highest quality PTO generator? #8
I wonder if a pto generator is the best way to go. Any natural disaster causing a power outage might also be a good time to have your tractor around for clean up activities, etc, etc. I might consider a stand alone Winco generator to free up your tractor.
   / Who makes the highest quality PTO generator? #9
I had a rather old 15K Onan. Came out of a chicken barn. Never gave me any problem. Yes, Winco also comes to mind for quality
I switched to a Onan stand alone, because quite frankly getting the PTO set out and on, in the dark was a hassle.
The power being out is often not as much of a problem as NOT knowing when it will come back on. Sometimes I JUST got the PTO set on, when the power resored!
But the biggest reason I went self contained is that I did not like the idea of my little JD 770 screaming away at FULL RPM without any means of auto shut down in a fault condition.
   / Who makes the highest quality PTO generator? #10
I liked the comment about my wife. She helps with farming and drives the tractors but I don't expect her to hook up a PTO genset. My 17KW generac comes online in 45 seconds and runs on propane and we have 1500 gallons on hand at all times so an extended outage is no issue. The Winco I had was absolurely trouble free and yes, it had a volt meter on it to set the input rpm. I sold it for not much less than I paid for it actually.
Now, if Generac made a PTO unit, I'd take a serious look at it. Generac is quality stuff too. They even build their own engines (for the smaller ones). As it is, I'm very happy with the Generac unit.
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
