RedNeckRacin
Elite Member
- Joined
- Jan 6, 2008
- Messages
- 2,506
- Location
- Western PA
- Tractor
- John Deere 5083E MFWD, Kubota L3400 HST
So I have been thinking. I have a 9' loader mounted plow that I have been less than happy with. I have it on a quick attach plate that allows the plow to float up and down and lifts wit a chain that can have thr length adjusted by using the curl cylinders to change the angle of the QA plate. I also have hydraulic angling via the rear remotes. Also I have only used the plow one winter so far.
My two main problems are with the ease at which the plow trips and how easily the plow angles when encountering a snow bank.
1. The plow tripping easily. The push frame being level gets the best results out of the straight plow but often enough i have to bump the loader arms up to keep from bottoming out on the ground. This wouldn't be as big of a problem if the areas being plowed were perfectly flat. The loader arms end up being so low they dig in or to high and the plow trips very easily. I was thinking of replacing the 4 trip springs with new ones and adding 2 more into the existing holes. In theory this should work alot better. I also have considered fixing the plow so that it won't trip at all. Keep in mind I only plow at a couple miles an hour with my tractor and not at 20mph like a truck would be.
2. The plow very easily deflects/rotates when I catch a snow bank with a single side. I realize that this isn't a dozer, but I shouldn't have to push a snow bank at 90 degrees or at full angle to move it back. My other plowing rig doesn't have this problem but it's only a 7 foot plow on a subframe mount.
So my solution comes in ditching the angle and trip functions of the plow all together and making it into a pusher box. I have to clear a decent sized parking lot, about 200' by 200' and a 1500' driveway. So this seems to be the ideal answer. I definitely have enough tractor to push more than the box could ever handle with 4wd and chains on my john deere. The only trick to the driveway would be the high tensile fence running down both sides that would limit where I could put the snow, but I really don't see a problem as I can easily take an extra bite or two. Snow depth really isn't much of a concern either since it rarely ever drifts and a record snow event would be 20+ inches. We generally see dusting to a couple inches normally.
So what do you guys think??
