Tiller question for the Mahindra Max 22
   / Tiller question for the Mahindra Max 22 #1
308snpr
Fombell, Pa
Mahindra Max 22
My Mahindra Max 22 rear PTO has 18 hp. What tiller can I run off of the 18 hp? I looked at the Mahindra 4 ft tiller but requires 20 hp. Thank you in advance for your help.
   / Tiller question for the Mahindra Max 22 #3
I have an emax 25hst and I'm running this model
Everything Attachments 48" Chain Drive Tiller
I've no issues with in regard to power, particularly since the hydro allows me to creep down the rows. I did and will continue to avoid subcompact attachments as the emax and max have a full cat 1 three point. I prefer to run the quick hitch works with the tiller I linked, furthermore the added three inches of the quick hitch saves you from having to cut the driveshaft.
Thank You both.. I'll let you know once make the purchase
   / Tiller question for the Mahindra Max 22 #5
I ran a 48" wide Yanmar RS1200 tiller off my 2005 Kubota B7510HST (21 hp engine, 17 hp pto) with no problem.
That tiller had no shear pin so I had to add a slip clutch in the pto driveline. The lower arms on the 3 point hitch that came with the 7510 were too short. So a used the longer arms from my 1964 Massey Ferguson 135 diesel tractor, the silver-colored things in the photo).
You might think about getting a middle buster plow for your Max 22. In hard ground it helps to plow the soil with the MB before trying to rototill.
Good luck
2014 Nissan Juke Multipurpose Vehicle (MPV) (A51694)
2014 Nissan Juke...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
Wright Sentar (A50120)
2006 CHEVROLET SILVERADO 1500HD (A52472)
2006 CHEVROLET...
