3616 HST loud noise when braking
   / 3616 HST loud noise when braking #1
JimnAZ
Seligman, AZ
None
I have 200 hrs on this tractor. Although I rarely use the braking system I have recently noticed that when I do, I hear a loud grinding sound from the back end. I've released the brake pedal so that I can use the brakes individually and hear the noise when using either pedal.
This is my first tractor so I am not familiar with a tractor's braking system and the owners manual does not mention anything at all.
Any troubleshooting I can do?
Thank you
Jim
   / 3616 HST loud noise when braking #2
very likely it's surface rust on the braking surfaces, which 'grows' there due to lack of use.
I bet if you press the brake pedal lightly and hold it there while driving the tractor, the noise will stop after a bit as the rust is cleaned off.
Cars that sit without brake use for a time will also make a noise like this until the surfaces 'clean themselves.
   / 3616 HST loud noise when braking #3
3616 has wet disks brakes running in hydraulic fluid so rust is unlikely cause of the noise.
   / 3616 HST loud noise when braking #4
oookay, I didn't know that....so the original poster should disregard my post....with my apologies. I learn something new everyday.
Is this the same hydro fluid used for the implements or is it the axle hydro fluid?
Sorry, I do not know how the brakes work on this tractor.
THX
   / 3616 HST loud noise when braking #6
The trans and the implements all use the same fluid. There is no other fluid other than engine oil and water in that tractor.
I just didn't know that the brakes are internal when I made my previous post.
Yes I know the same fluid but is it all from the same reservoir? I thought the axles had to be filled separately.
   / 3616 HST loud noise when braking #8
the front axle is on it's own and needs it's own drain and fill. It is not connected hydraulically to the main fluid reservoir but the rear is.
   / 3616 HST loud noise when braking #9
There isn't much you can do without a shop manual and some serious grunt work - may be time to get a professional diesel mechanical to take a look.
   / 3616 HST loud noise when braking #10
THX
Yes HST tractor uses the same fluid for hydraulics and gears (such as PTO(s), rear differential, speed ranges etc.) The HST and hydraulic system have separate pumps. Some tractors also have second pump for steering. The brakes are internal to rear axle. Engine and front axle each have separate oil from hydraulic system.
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
90018 (A48082)
90018 (A48082)
LOT LOCATIONS (A52576)
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
