Need help with overheating problem
   / Need help with overheating problem #31
I don't know this tractor. Some times you have to replace cylinder bolts because they are stretched an don't torque right. Also make sure the bolt holes in the block are clean ( blow out ).
If cylinder linings are replaceable, the seal under one might leak. (then it shows coolant in the engine oil as well).
And for sure you do not want coolant in the oil; that could render the engine into a boat anchor.
Problem solved.
It was a leaking valve seal.
sleeves replaced and it it magnafluxed tight,
-Thanks to all.......
-Mike
2007 FREIGHTLINER BUSINESS CLASS M2 DUMP TRUCK (A51406)
2007 FREIGHTLINER...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
ASSET DESCRIPTIONS & CONDITION (A54607)
ASSET DESCRIPTIONS...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
