JD 6210 Three Point Hitch slow
   / JD 6210 Three Point Hitch slow #1
VE1967
Tupelo, MS
JD 6210
I have an open station 1999 JD 6210 with a 640 FEL. The FEL operates normally as well as the cylinders on my grader blade. The three point hitch raises normally (when using the "up" button). However, it is very slow and unresponsive when I try to lower or make height adjustments to a 3 pt implement (even a fairly heavy grader blade).
Any help would be appreciated.
Thanks
   / JD 6210 Three Point Hitch slow #2
You know there is the speed control pot under the little flip up cover? Does it work?
Two pots. One controls speed (can't remember if it's up and down or just down) and the other controls maximum height.
Not sure about the draft control knob. Never did figure that one out. Just turn it off CCW until it clicks.
Yes. I had checked that and the speed control pot was set to the highest setting. I will double check just to make sure.
Thanks.
   / JD 6210 Three Point Hitch slow #4
Try it the other direction. Maybe the pot is bad. Sometimes just working a pot back and forth will restore operation. If not, some good zero-residue cleaner might help if you can get at the wiper inside. Sometimes if a pot is sealed, you can drill a tiny hole to spray in the cleaner. JD probalby wants enough money for a new pot.
   / JD 6210 Three Point Hitch slow #5
I agree. Crank that thing around... I bet it will clear up.
I'll give it a try.
Thanks.
I shoulda thought of that!!
As you might have already guessed, that worked.
I am very grateful for the advice and more than a little embarrassed.
Thanks again.
   / JD 6210 Three Point Hitch slow #8
I shoulda thought of that!! As you might have already guessed, that worked. I am very grateful for the advice and more than a little embarrassed. Thanks again.
Great news!
Hey, lose the embarrassment! It happens. I once looked for my sunglasses for a half hour while they were on the bill of my cap. Anyone who says they don't do something dumb is lying.
Sent from my iPad using TractorByNet
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2005 Ford F-250 4x4 Reading Crane Service Truck (A51692)
2005 Ford F-250...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A53426)
2015 INTERNATIONAL...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
UNUSED JMR 40" HYD GRAPPLE BUCKET (A51248)
UNUSED JMR 40" HYD...
