Searching for 2810 HST relay pigtail
   / Searching for 2810 HST relay pigtail #1
cgiguru
Gardner, KS
Mahindra 2810HST, Yanmar 187D
I need to find the add-on 2810 HST relay pigtail that was discussed at length in this old post http://www.tractorbynet.com/forums/mahindra-owning-operating/74223-2810hst-modification.html . It doesn't show up in the wiring diagrams at the dealer and Mahindra doesn't seem to be able to find it. This is all I need to get up and running again. Mine is burned beyond recognition. Does anyone have the part number for this pigtail or know where I might be able to get one?
Thanks!
http://parts.mahindrausa.com/dealerview/illustrationview.aspx
The flasher relay? or the #10 relay?
Hopefully you just need the relay side and not what it plugs into... if so youll either have to buy the whole harness or find one just like it and splice it in.
Can't log into this dealer site. Can buy the relay anywhere for $8. Need the pigtail with the connections. It's not part of any other wiring harness listed in the parts catalog. Anyone know how to get this pigtail?
   / Searching for 2810 HST relay pigtail #4
hmm guess it linked wrong.
So it is the flasher relay or a different one?
The flasher relay is on the other side of the firewall under the dash. This doesn't have anything to do with the flasher from what I can tell. It's a add-on fix provided by the manufacturer that splices in between the fuse box, main and engine wiring harnesses to stop an electrical issue that was frying the controller box and solenoids.
   / Searching for 2810 HST relay pigtail #6
Ok that's what I was needing. Its a second glow plug relay.
There is a part # for the Relay Harness Assbly 14786689990
Thanks Navasot. I'll check it out.
   / Searching for 2810 HST relay pigtail #8
No problem. you wont be able to find it in the new style parts look up. Just tell your dealer to plug it into their shopping cart and it will pop up.
   / Searching for 2810 HST relay pigtail #9
Charles Huff sent me one a few years ago. They were about $100, if I remember correctly. This is what you are looking for.....
   / Searching for 2810 HST relay pigtail #10
I am looking for a controller for a 2810 HST, in the event anyone may know where a used one may be located. I bought the harness, just never replaced the controller.
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
1997 JOHN DEERE 544G WHEEL LOADER (A52472)
1997 JOHN DEERE...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
