JD 750? anything to look for
   / JD 750? anything to look for #1
ohmyback
Missouri
JD 750 GC1705
Going to look at very clean 750 with 1200 hrs.
I am newb anything I should look for? It has fel & rfm.
   / JD 750? anything to look for #2
Overall condition and history of the tractor. One or two owners best and long ownership of the last owner a good sign. Look at the oil and if it was me and I could do it without a hassle I would look at the air filter. Overall condition probably the best indicator.
Thank you!
Was mainly looking at new tractors & this one popped up. From the pics it is very clean. The bucket is nice and straight, hardly looks used.
price is right so I hope it checks out. I guess this is a decent model?
One other thing. Are you still able to get parts if needed?
   / JD 750? anything to look for #5
Depends on what part. You are starting to run into NLA (No Longer Available) with some items
   / JD 750? anything to look for #6
They made a LOT of this series and I can't imagine ever being denied a part if you use the dealer, the aftermarket and boneyards. Maybe a block if it was a specific size and you wanted new but there are too many of these around for a complete abandonment. I had a 950HC once and was surprised at the interchangeability of parts from the 650? to the 950.
   / JD 750? anything to look for #7
Like you said, it is just a matter of how much effort you can put into it
   / JD 750? anything to look for #8
I bought one new in 1988 and kept it for 27 years. The only problem I had that wasn't a direct result of operator stupidity was the alternator and the regulator/rectifier module, both still available.
I might look elsewhere if it's not 4 wheel drive (actually "Mechanical Front Wheel Assist" or MFWA) as it's pretty light and can use all the help it can get for traction.
I ran a 5' bush hog, a 6' finish mower, log splitter, 4" chipper, 5" box blade and a Woods 650 backhoe with no problems whatsoever, power-wise.
A fine, rugged and economical tractor. Only reason I traded is I wanted a cab, power steering and live PTO.
   / JD 750? anything to look for #9
Don't know if this picture will load.
Brought her home today.
1093 (A58374)
1093 (A58374)
1328 (A58374)
1328 (A58374)
2007 International 4300 (A53314)
2007 International...
EZ loader trailer (A56857)
EZ loader trailer...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
