JD 750? anything to look for
   / JD 750? anything to look for #1
ohmyback
Missouri
JD 750 GC1705
Going to look at very clean 750 with 1200 hrs.
I am newb anything I should look for? It has fel & rfm.
   / JD 750? anything to look for #2
Overall condition and history of the tractor. One or two owners best and long ownership of the last owner a good sign. Look at the oil and if it was me and I could do it without a hassle I would look at the air filter. Overall condition probably the best indicator.
Thank you!
Was mainly looking at new tractors & this one popped up. From the pics it is very clean. The bucket is nice and straight, hardly looks used.
price is right so I hope it checks out. I guess this is a decent model?
One other thing. Are you still able to get parts if needed?
   / JD 750? anything to look for #5
Depends on what part. You are starting to run into NLA (No Longer Available) with some items
   / JD 750? anything to look for #6
They made a LOT of this series and I can't imagine ever being denied a part if you use the dealer, the aftermarket and boneyards. Maybe a block if it was a specific size and you wanted new but there are too many of these around for a complete abandonment. I had a 950HC once and was surprised at the interchangeability of parts from the 650? to the 950.
   / JD 750? anything to look for #7
Like you said, it is just a matter of how much effort you can put into it
   / JD 750? anything to look for #8
I bought one new in 1988 and kept it for 27 years. The only problem I had that wasn't a direct result of operator stupidity was the alternator and the regulator/rectifier module, both still available.
I might look elsewhere if it's not 4 wheel drive (actually "Mechanical Front Wheel Assist" or MFWA) as it's pretty light and can use all the help it can get for traction.
I ran a 5' bush hog, a 6' finish mower, log splitter, 4" chipper, 5" box blade and a Woods 650 backhoe with no problems whatsoever, power-wise.
A fine, rugged and economical tractor. Only reason I traded is I wanted a cab, power steering and live PTO.
   / JD 750? anything to look for #9
Don't know if this picture will load.
Brought her home today.
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A55973)
Miller and Smith...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2013 Ford F-750 Pak-Mor 16 Yard Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
BUSH HOG 8 SHREDDER (A58214)
BUSH HOG 8...
