LD1
Epic Contributor
Oh boy.
With needle valves closing off the cylinder, you could take the whole freaking piston out, seals and sll/, and it still ain't gonna move. PERIOD.
If it did, it could only be caused by an external leak at the fitting BEFORE the needle valve, or a leaking gland seal. BOTH would be clearly visible by the puddle of oil.
The pressure difference could be 10000 psi for all I care. The fraction of a thousandth of an inch that the rod may move will equalize the pressure since fluid don't compress. Even if there is a tad bit of air in the cylinder, once that void is taken, all movement stops. It isn't going to continue to drift at a steady pace until its on the ground.
I AM making a definitive statement that the spool valve is the only way a loader will drop...PROVIDED there is no external leakage of the hoses, fittings, gland seal, etc.
I am glad you finally admit that the valve is the major cause for loader drop. When did you change your time on that?
