8560 clutch wont disengage
   / 8560 clutch wont disengage #11
I know this should go without saying, but do make sure if you are doing the "slam the brakes" trick that the clutch pedal is also all the way to the floor when you do it.
We had an older but very low hour and very clean Kubota in the shop recently for a stuck clutch. We bumped it a few times and it was really stuck. We split it and were glad we did. The flywheel was deeply rusted and pitted. 135 hours if I recall correctly and the tractor was clean as a pin. Not sure how it go so very stuck. We have a dry climate, so we only see this a time or two a year. That and the fact that most folks do not park there tractor for months on end. Frequent use generally keeps this from happening.
Good luck, I hope you get it.
   / 8560 clutch wont disengage #12
Youll want to take the mower off and get it in high range
Why wood the bush hog being hooked up matter? I had it in high range 4th gear with the hog hooked up. I was flying down the hill. It's the only time I actually thought I might ort to have put my seat belt on!!
   / 8560 clutch wont disengage #14
figured youd be pullin a large pull type mower and wouldn't be fun to tow
   / 8560 clutch wont disengage #15
Ok that's a bit to fast lol... I ment like high at 1st or 2nd
THANKS. Tried it today after work. Took 3 more tries and on the last one it broke free. Thank you to everyone who replied to my post. Will it hurt the pressure plate and throw out bearing to prop the clutch pedal down when not in use?
   / 8560 clutch wont disengage #17
Good! With some wear the problem should go away if you run it a bit more often. Mine [7520] used to stick after a few days. No hint of sticking now even when it sits a couple weeks. ... Seems problem went away at about 200hrs. Tractor is nearing 1500hrs.
   / 8560 clutch wont disengage #18
Nope, some brands/models have hooks to hold the pedal down. My brother's Kioti does.
   / 8560 clutch wont disengage #19
My 3016 does lock it down everytime I park it
Sent from my iPhone using TractorByNet
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
2012 CHEVROLET EXPRESS (A52472)
2012 CHEVROLET...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
CENTRAL PNEUMATIC  GAS 135 PSI (A52472)
CENTRAL PNEUMATIC...
