Anyonr recomend a good lawn roller for Kubota BX
   / Anyonr recomend a good lawn roller for Kubota BX #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
Every review of the ones im finding say they leak or break within a year or so.
   / Anyonr recomend a good lawn roller for Kubota BX #2
I made one out of a 5' section of 12" schedule 80 pipe and welded in 1/4" end plates. It has been going for 10 years with no problems. My father-in-law bought a 48" roller at Lowes several years ago and it cracked at the seam on the second year, he welded up the crack and filled it with quickcrete, it has been going for the last 5 years without issue.
   / Anyonr recomend a good lawn roller for Kubota BX #3
I went through 2 of those hardware store rollers. I finally bit the bullet and bought one from a local iron fabricating shop. It is 6' wide and 18" tall. It has enough steel in it that it weighs 350lbs empty. I have.had no problems in 4 years, including using it on food plots the last 2 years.
Will
   / Anyonr recomend a good lawn roller for Kubota BX #4
I bought a 'made in China' 3PT roller which was bearing-slung under the frame. The strain of that configuration would've put too much supporting pressure on the bearings, so I dismantled and re-installed the bearings on top of the frame.
I did find one leak around the fill-cap weld. A bit of steel-putty (a 'plasticine' compound that hardens solid) solved that problem.
The attached photo is what the implement looked like when I first received it.
   / Anyonr recomend a good lawn roller for Kubota BX #5
I've found a couple of pictures of my roller post-conversion.
I did have to shift the centre aerating band IOT avoid hitting the back-brace. As long as you roll straight and lift the implement to make a turn or set up for the next 'line', there's no problems that I've encountered.
   / Anyonr recomend a good lawn roller for Kubota BX #6
"The strain of that configuration would've put too much supporting pressure on the bearings, so I dismantled and re-installed the bearings on top of the frame."
The only things you have changed is taking the bearing mounting bolts from compression to tension and increased the clearance for the roller when the implement is lifted.
   / Anyonr recomend a good lawn roller for Kubota BX #7
G'day orangeandgreen. Yes and no... firstly, I did this on the recommendation of the bloke who sold it to me (or re-sold it, as it came from China). He'd had a number of previous sales break due to the original configuration and this suggestion was the work-around. Secondly, due to the weight of the loaded (water with a wee bit of anti-freeze) drum on the four bearing mounting bolts in the suspended (underneath) configuration, it would quickly (time wise) shear the bolts with the constant up/down & tractor manoeuvring wobbles/vibrations when setting up for the next pass.
Supporting the bearings on top of the frame reduces those stresses. The aerating spikes are bolted on as a 'strap' and can be removed if I simply want to roll. The other option would have been to purchase a towed roller, but I have small horse paddocks with limited manoeuvring space to utilise that type.
Duck, that's one I was looking at and had a lot of bad reviews maybe you got lucky or got one before they started making them cheaper?
   / Anyonr recomend a good lawn roller for Kubota BX #10
Best roller I saw was a homemade one. It was a old roller cylinder from a paper mill I think. It had real bearings on the ends and was solid. The drawback is its always heavy. The weak link on the newer ones is where they attach to the arms. If bearings could be added, they would be much better at lasting
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
Guard Rail Joints (A51692)
Guard Rail Joints...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
