Kioti RX6620-RX7320 VS. Kubota M6060-M7060
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #1
mulespb
Springfield, MO
Kubota L3400HST, JD 4020, Farmtrac 435, Kioti RX6010C
I'm just a farmer who owns both Kubota and Kioti products. I have an L3400HST Kubota that's been bulletproof. Owned a L4400HST that was good too but sold it to buy a cab 60HP Kioti RX6010C with 200 hours on it. Based on experience the Kioti is not made and engineered nearly as well as the Kubota products.
I've fought the RX6010 running too hot even though I clean and wash out the radiator, checked hoses and water pump and made sure coolant mix is good. The tractor doesn't have the torque a 60HP tractor should have. Kioti rates their HP at 2600 RPM and the Kubota M6060 or M7060 rates theirs at 2400 RPM. The Kioiti uses a 148.5 cu.in. motor and Kubota uses a 203 cu.in. motor. Those extra cu.in. seem to make a big difference in torque, even though the HP numbers are similar.
Recently snapped a clutch cable at 280 hours shutting me down in the field, and of course the Kioti dealer doesn't have one in stock. If I had it to do all over again I'd opt to buy a Kubota M7060 and spend a little more, but have something that works all day.
  • Good Post
Reactions: HEC
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #2
Thanks for your input. I have been looking at these two units myself and will have to decide between them.
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #3
Do you think Kubota dealers keep all of there parts in house in stock?Heck know they don,t,I speak from experience.Waited 2 plus weeks on axle parts for my 2006 kubota RTV.Just a option here if you really don,t like your Kioti tractor SELL IT..
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #4
I've often wondered about that 2.4L turbo engine in the RX and how it does at the low RPM. Is it low on torque just at idle or is it also low on torque at 1500 RPM... 2000RPM. I really like the RX platform and could seem myself going to one in the future. However, I can't stand low torque engines in a tractor. (heck I can't stand low torque engines in anything!). I have a Kioti DS4510HS and it's been perfect so far but I only have 150hrs so it should be perfect. It has a naturally aspirated pre-Tier IV engine 2.2L and I think the torque is great. It's rated at 2600 RPM also but the torque feels like it rises down to 1700 RPM and then holds almost flat down to 1000 RPM which is idle speed. What is the shape of the torque curve on the RX?
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #5
I am surprised to learn the RX models even use a clutch cable. It's all rigid linkages on my DK. I guess we need to extrapolate CK/DK experience with care.
Not sure if I'm expecting too much but the RX6010 struggles alot in anything over 10 inches of grass with the 8 ft. BH3008 twin spindle cutter. I used it behind my Kubota L4400HST and it struggled of course, and I wanted a cab anyway, so I sold it and bought the RX6010 and thought it would handle it fine. It does not have any power at all below 2000RPM, and I spin it about 2300 under load (Will dog all the way to a stall in heavy grass). In contrast, my 3 cyl. Farmtrac 435 (35HP) turns 1800 and plows thru heavy stuff with a 6ft cutter with ease. My Kubota L3400HST even handles a 6ft hog but I've got to go pretty slow.
If I could sell my RX6010 and get anywhere close to my investment back I would, but I think I'm stuck with it. And yes, a tractor that size shouldn't use a motorcycle type cable to control the clutch.
I agree......using a motorcycle type cable for a 60-70 HP Utility tractor is crazy, and a very bad design. Only good thing was cable was only $30. I ordered an extra for the next time it breaks, maybe 200-300hours more. LOL
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #8
TROLL alert..IMHO..
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #9
Thank you very much for posting about the 6010. I am really looking at the 7320 but am just worried as I have always been a Kubota guy and don't want to get stuck with a tractor that I am disappointed with and cant sell. Thanks again, Glenn
   / Kioti RX6620-RX7320 VS. Kubota M6060-M7060 #10
Coobie, grow up. Just because someone doesn't have glowing reviews of your favorite brand doesn't mean you can act a child and call them pathetic names.
3-Bottom Mold Board Plow (A53316)
3-Bottom Mold...
2020 Kubota KX033-4 Mini Excavator (RIDE AND DRIVE) (A50775)
2020 Kubota...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
1831 (A51247)
1831 (A51247)
Excavator Bucket (A53316)
Excavator Bucket...
