5 foot brush hog on my Max25
   / 5 foot brush hog on my Max25 #1
garye5007
Member
Glastonbury, Ct
Mahindra Max 25
hi,
Would by Max 25 be able to handle a 5 foot brush hog?
Thanks, Gary
   / 5 foot brush hog on my Max25 #2
following the rules of 5 PTO HP per foot of cutter, it would probably be a tough go.
Thanks for the fast reply!
I was looking for a 4 footer but I saw a 5 ft for $300 so i thought I would check...
Thanks again!
   / 5 foot brush hog on my Max25 #4
I would have to say it depends on what you are cutting and how fast you want to cut it. I run a 6ft behind my Branson 2400h but that is to allow me to mow between the blueberries and maximize the cut. I also do not go very fast between them. It does cut my time down from 4 hrs to 2 hrs since I no longer have to make two passes in each row. Which I had to do with the riding mowers. DSCF0991.jpg
   / 5 foot brush hog on my Max25 #6
I run a 5' bush hog behind my 28hp Montana. Has no problem with a field with grass and weeds 3-4' high. You may not be able to mow at 20 mph, but unless its a golf course, usually the terrain limits speed anyway.
   / 5 foot brush hog on my Max25 #7
Also, can your 3PH handle the weight of a 5 footer?
Steve
It will handle the weight no problem.. since it is HST your gona find times it dosnt like a 5ft mower in heavy grass so just slow down a bit.. but regular kept stuff wont be an issue.. I have a customer running a 5ft shredder on a 2015 Mahindra (20hp) and says it runs it fine.
   / 5 foot brush hog on my Max25 #8
Advice is correct. If 5' rotary cutter is in ok shape for $300, get it.
   / 5 foot brush hog on my Max25 #9
I agree. I run a 5' cutter behind a B7500 (16 PTO HP) and it handles it ok as long as I go slow. You might need to disconnect the toplink to let it lift the front of the cutter a little easier.
Aaron Z
   / 5 foot brush hog on my Max25 #10
I've used a 5 ft. King Kutter behind a 9N and 8N for years, horsepower is about the same as the Max25. Just have to run in 1st gear.
2013 INTERNATIONAL MA065 CAB AND CHASSIS (A52472)
2013 INTERNATIONAL...
Kubota ZG327 (A50120)
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A52748)
2009 Ford F-650 24...
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
2008 New Holland B110 MFWD Loader Backhoe (A52748)
2008 New Holland...
