What size hydraulic cylinder do I need?
   / What size hydraulic cylinder do I need? #1
D0TC0M
NB, Canada
Foton TE254A
My snowblower has a manual lever to adjust the up and down of the chute. I want to install a small hydraulic cylinder. I would need about a 6"-8" stroke but what size bore should I use? If you have any links, i.e. ebay, to specific cylinders that would do the job it would be appreciated.
Also I have a foton 254 with a multivalve with 4 connection ports at the back of the tractor. I already use one for the side to side movement of the chute. I am going to use the other 2 connectors for the up and down function. When I build the hoses for this cylinder what type of connector do I need to connect to my hydraulic connectors on my tractor?
   / What size hydraulic cylinder do I need? #2
Things to remember about hydraulic cylinders. The smaller the bore for a given flow rate of the pump, the faster the cylinder will cycle. Also the smaller the bore, the less force it will exert for a given pressure relief valve setting. Conversely the larger the bore, the slower the cylinder will cycle for a given flow rate, and it will exert more force than a smaller bore for a given pressure relief valve setting.
In you application, you need next to nothing in the way of force, and you probably don't need a whole lot of speed either. Make sure the stroke will bottom out before it tears your chute up. You may need a needle valve flow restrictor to slow down the movement.
Yes I plan on fabricating my chute linkage so that the cylinder bottoms out without tearing up my linkage. Thanks for reiterating that important point. I am assuming since I will be bottoming out before the linkage that the amount of force is kinda irrelevant. I am trying to size the bore so that I get the speed of travel around where I need it. I'm trying to get away from using a needle valve because I don't want the system pressure to spike every time I adjust the chute. The multivalve has a common relief valve for both outlets.
   / What size hydraulic cylinder do I need? #4
Hydraulic chute deflector cylinder mounted 2.JPGHydraulic chute deflector cylinder mounted 3.JPGHydraulic chute deflector cylinder mounted 6.JPGHydraulic cylinder  mounted quick release 1.JPGHydraulic cylinder  mounted quick release 2.JPGHydraulic cylinder  mounted quick release 3.JPGHydraulic cylinder  mounted quick release 4.JPGSnowblower hydraulic chute deflector cylinder, custom made bracket, hose adaptors and connectors.JPGSnowblower hydraulic chute deflector ready for cylinder bracket to be installed.JPG
I bought my cyl. at Princess auto. Smallest one they sell.
Cleat
Thanks for replying with pictures. :) That is exactly the setup that want.
From the pics it seems you have the the 1" bore x 4" stroke here or the 1-1/2" bore and 4" stroke like in this link. Can you confirm which you have?
How fast does yours move in operation?
   / What size hydraulic cylinder do I need? #6
You should also ask his flow rate and compare that to your tractors pump flow rate.
   / What size hydraulic cylinder do I need? #7
The first link to the 1 x 4 is correct. I have it hooked up with 1/4" hoses to help slow it. I think the pump is 8.5 GPM.
If you just yank the rear remote lever it moves quite fast, but if you feather it a bit it works fine.
I also have hydraulic rotation but that uses a motor so it is a little slower.
Cleat
Thanks Cleat and k0ua I think I have what I need
   / What size hydraulic cylinder do I need? #9
As said, smallest cylinder available (of right stroke) and you can simply insert a 'flow restrictor' in the circuit.
You can also make a restrictor (using an appropriate to the hose and fittings) male/female fitting and welding shut the passage and then drilling a much smaller passageway.
But at that restrictors are available in the $5,00 range or so.
More than once I have made some however as it was more convenient than going to a shop and finding 'no stock' on hand.
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
Kubota RTV-X900 4x4 Utility Cart (A51691)
Kubota RTV-X900...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Adams 5 T Spreader (A53473)
Adams 5 T Spreader...
