What is latest opinion/position on BX series slow braking (is it an issue or not)?
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #1
mshumack
Central FL, Florida
2015 Kubota BX2370 w/ FEL and MMM
I have seen several videos and threads complaining that the BX70 series tractors don't stop quick enough when your foot is removed from forward/reverse pedal. One person/post said it is normal as long as tractor stops in less than 10 feet according to the manual (I have not seen this myself in the operators manual I downloaded).
Some say its a dangerous condition but Dealers won't fix (because Dealers say its normal), other owners say it is working fine and they prefer a gentle stop rather than an immediate stop when lifting foot.
Is it just personal preference - or is this a safety issue?
If you are on a hill will the tractor continue to roll or does it come to a stop in 5ft+/- no matter the grade? Do you just rely on the parking brake pedal to stop you?
I'm going to try a BX2370 tomorrow and need to decide rather quickly since the 0% financing program ends next week.
I'm sorry I saw these threads/videos now, as I have real concern. I don't want to get into a situation where I need to stop quickly and can't. :confused:
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #2
All I can tell you is of the three hydro tractors I have owned. A New Holland, a Kubota and now the Kioti. It is not normal. The hydro should stop you rather abruptly if you jerk your foot off of the pedal even on a hill. After a few seconds on a steep enough hill they will drift downhill like a snail if you do not press the brake or a little reverse direction pedal. But we are literally talking a snail's pace of the downhill drift. To come to a smooth stop in a hydro tractor you release the directional pedal slowly or the stop will be quite abrupt. This is the way all three I have owned have worked.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #3
Mine is within the specs, cant find it right now, I had posted them before. My first tractor so its what I'm used too, no problem. A little common sense goes a long way. My land is mostly flat so I just put the front bucket down and no brakes. My dad has the JD 1025 and forgot to put the bucket down and/or set the brakes and found it half way down the ravine, he knows better, also no damage, he's lucky.
I just went through the Operator's manual again and it just says under "Stopping" to "Step on the brake pedal". There is no reference to coasting/rolling a certain distance after lifting foot from speed control pedal.
I have an appointment to drive one tomorrow and see how I like it.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #5
When you buy it just take the little shock cyl off of the shifting lankage and keep greased. The grease fitting is under a little door in the floor mat.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #6
I don't believe it is dangerous at all. I personally find the small amount of creep no big deal but other people really dislike it. I think if it is your first tractor it would not be a big deal because you sort of learn its "style" and just get used to it. I used to drive geared tractors for work 40 hrs a week so to me the idea of hitting a brake or planning your stop is not an issue. It seems that if you are used to a HST that stops on a dime (Quickly) then it may bother you because it does not lock the wheels when you let off.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #7
I have had four Kubotas, still have three, two John Deere SCUTs and still have one and pretty much agree with James k0ua. I would be very uncomfortable with one on which you had to brake to stop, I can't remember the last time I use brakes on any of them beyond holding absolutely still on a steep slope.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #8
I was able to find the stopping distance allowance in the workshop manual. If I can remember tonight, I'll try and post a picture.
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #9
It seems the dampener they put on to avoid the abrupt stop now makes it slow so gently it creeps - they just need to find the happy medium!
   / What is latest opinion/position on BX series slow braking (is it an issue or not)? #10
I agree, loading a truck or working with a groundman doing landscaping could really be bad.. I would not like it at all.
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
TMA (A49461)
TMA (A49461)
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2016 UTILITY VS2RAP 53FT REEFER TRAILER (A54607)
2016 UTILITY...
