New taller tractor
   / New taller tractor #1
escavader
western maine
bx-23 ,
Im gonna have to redo all my pro shafts aren't I?? They won't be long enough now correct?
   / New taller tractor #2
You might be surprised that most of the implemempnts may still be a usable, safe fit even with the taller tractor. Mount each implement to the tractor and see how much overlap you have in matching the male and female shafts with the implement in the extreme lifted and lowered position. If there is plenty of overlap of the shafts in the lowered position and no binding in the upper position you are good to go.
   / New taller tractor #5
I have never had to put on a new PTO shaft going from as little as 35 HP up to 70. Just check the shaft as Utopia Texas said and you should be good to go.
   / New taller tractor #6
thanks didn't know they made such things
They are made mostly for people who add quick hitches. When I added the Pats Easy Change to mine, I had to get one to make up the extra 4" that it moved the attachment away from the PTO output shaft.
I went from a bx with very little ground clearance way up to a tall b must be at least a foot thinking might have issue
   / New taller tractor #8
What kind of junk PTO shafts are they making now that you have to buy an extender for 4"? I know I'm not up to date on my equipment but all my PTO shafts have a good 24" of slide. Adding a quick hitch was no problem at all. ??? :confused:
Added: The only time I could see a difference in height would be maybe if the 3-pt hitch is a different category. The 3-pt hitch move perpendicular to the ground and the output shaft is usually centered on that.
2012 KENWORTH T 7 DOUBLE BUNK SLEEPER (A52576)
2012 KENWORTH T 7...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53472)
2011 New Holland...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
