Will a 3/8" - 1/2" chain binder fit 5/16" chain.
   / Will a 3/8" - 1/2" chain binder fit 5/16" chain. #1
buddy48
Dearing, Ga
Kubota L3901
Seems like it should....
   / Will a 3/8" - 1/2" chain binder fit 5/16" chain. #2
Overkill but yes it will.
   / Will a 3/8" - 1/2" chain binder fit 5/16" chain. #3
If you have to buy some, get the ratchet binder with a folding handle. :thumbsup:
   / Will a 3/8" - 1/2" chain binder fit 5/16" chain. #4
If you have to buy some, get the ratchet binder with a folding handle. :thumbsup: <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/442159-will-3-8-1-2-a-h5125-jpg"/>
Why are they better to get than the standard ratchet binder?
   / Will a 3/8" - 1/2" chain binder fit 5/16" chain. #5
The main thing that I noticed is with the handle folded, they drop in the bucket where I store the tiedown chains. :thumbsup:
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
New Holland 308 Manure Spreader (A59814)
New Holland 308...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
