MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,759
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
2013 Impala.... My kid called me from her job the other day.... Dad, the key turns, but the car won't start, I can't get the key out and the radio is making weird noises, and there's weird lights on the dash.
I talked her through a few things, but was stumped, so I went over there and it appeared the battery had died. I could turn the key to ACC and run and start, but it wouldn't start. I just couldn't turn the key back that last little click to get it out... so I popped the hood and jumped it from our Suburban. A few seconds after I had the jumper cables connected, I heard the warning chimes dinging in the car to tell us the key was in the ignition. I could then take the key out. Remove the jumper cables and I couldn't get the key out. Hmmmm.... never heard of that one before.
Anyhow, we jump started it and I warned her about losing power steering and brakes if it dies and we took small backroads home at low speeds. I pulled the battery. That's no easy task anymore, either. Required a 10mm socket for the battery cables, 11mm socket for the fuse box (you have to move the fuse box), 1/2" socket for the battery hold-down clamp and three bolts holding a brace between the fender and hood, a small screwdriver to pop a retainer lock out of a cable connector that runs over the battery, and then you have to turn the battery 90 degrees onto its short side and lift out! Yikes! They utilize every bit of space in there for sure. Took the battery in and it had a bad cell. $130 and 45 minutes later, all was well again.
Apparently this is a common situation (I won't say problem since it appears designed in) in many Chevy models.
So what's the purpose of not letting the key out if the battery dies? Only thing I can think of is to prevent someone from turning the key all the way back and locking the steering wheel while in motion. Any thoughts?
