Intek 22hp death rattle
   / Intek 22hp death rattle #1
wallypedal
Torrington Wyoming
JD 3020
That's what mine had - a death rattle. This is a replacement engine that we truly babied and it has about 300 hours on it - bought in 2006.
I shut it down after cooling at idle always, let it just run at idle for 2-3 minutes. I hosed the deck, popped the hood, and rinsed off some of the accumulated grass and crud. Not super power washed, just hosed. Let it drain dry for an hour or so.
Went to start it and it cranked but didn't want to go. Usually 2/3 throttle and full choke is all it needs. I figured I hadn't let it dry enough and something electrical was wet. It finally sputtered and started - but there was a new and very unhealthy rattle/knock going on, so I shut it down.
Took it in the garage and started once more - no better, shut it off. Pulled the cowl off and pulled the spark plugs and the valve covers. No obvious problems with pushrods or valves. When I turned the flywheel there was a tight spot right when #1 was at TDC. I could pull it past the "tight spot", but it just wasn't normal.
I took #1 head off and there was a piece of metal about 3/32" diameter and 5/16" long. The hammered remains of a choke plate screw!! BOTH choke plate screws were gone! The top of the piston had sort of a shot peened appearance from running with that in there - but no other damage. I don't know where the other screw went, it could have gone through without damage. Maybe.
I told Briggs support and they were no help. I cleaned it all up and re-assembled with new gaskets and adjusted the valves. I used new socket head choke plate screws with blue Loctite, and smashed the exposed screw tips with vice grips. I don't think they'll come loose again. Briggs uses purple Loctite only - the wimpy grade.
It runs better and smoother than it has in a long time!:)
Wallypedal
   / Intek 22hp death rattle #2
Wow. You would not think you would have to worry about the choke plates. I guess a new maintenance check on gas engines.
Glad no major damage was done.
   / Intek 22hp death rattle #3
Interesting story, glad you are up and running again without to great a headache. Have you checked inside the muffler for the other screw?
   / Intek 22hp death rattle #4
choke or throttle plate screws coming out is not all that uncommon.
Walt Conner
   / Intek 22hp death rattle #5
Wallypedal
That happened to a Dodge Omni I bought new, ate one throttle plate screw and the plate shifted and jammed the throttle open, made for a fun ride home. No damage that I could tell, I think it spit the screw out after a brief rattle. Never ran differently, no excess oil consumption. Traded for a Honda Accord.
2022 UTILITY FS2CHA 48FT FLATBED TRAILER (A53426)
2022 UTILITY...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
2014 AMADAS SPC-6-36 LOT IDENTIFIER 196 (A53084)
2014 AMADAS...
HANG ON MAST W/ 58" FORKS (A51247)
HANG ON MAST W/...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
