What's missing on this bush hog?
   / What's missing on this bush hog? #1
joybuz
Germantown, TN
2003 New Holland TC30
Hi All, I'm new to tractors and this forum.
I just bought a 2003 TC30 that had several implements with it.
I'd appreciate some help identifying what's I need to run this bush hog. I think there's something that's missing between the gearbox and the shaft bushHOG.jpg?
Thanks,
Don
   / What's missing on this bush hog? #2
The shaft probably doesn't go with that shredder, is there any tag on it with a model number on that shredder. Looks like it hadn't been used in awhile.
Yes, it's an agri four.
   / What's missing on this bush hog? #4
That one uses a shear-bolt instead of slip-clutch. A yoke with a u-joint should slide over that shaft, that snap ring keeps the yoke-driveshaft on should it shear the bolt. Shear-bolts can be a real pain.
   / What's missing on this bush hog? #6
I'd appreciate some help identifying what's I need to run this bush hog. I think there's something that's missing between the gearbox and the shaftView attachment 442810?
Thanks,
Don
Put a slip clutch in there. Available from TSC going from shearbolt socket to 6 spline male.
   / What's missing on this bush hog? #7
Ditto, use a slip clutch.
But verify the other end of the shaft actually hooks to the tractor and is not a smooth bore/with hole for slip clutch. Would be a PITA is you hook the slip clutch up and realize you cannot hook to the tractor cause the other end aint splined.
10 in Small Excavator Bucket (A52377)
10 in Small...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
New Wolverine Skid Steer Hydraulic Breaker (A53002)
New Wolverine Skid...
2005 KOMATSU PC400LC-7L EXCAVATOR (A51246)
2005 KOMATSU...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
