newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,820
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
It's tractor selling/buying time again and lot's of people are comparing tractors and often they compare clocks.
I'm not trying to establish if 5,000 hours is an "old" tractor or 500 hours is a "new" tractor.
I'm trying to figure out if there is any general rule that brands/models use to track time on their clock.
from the past:
2007
And there is "time when the clock is on even if the engine isn't running":
A recent thread
Some of us leave the tractor idling rather than turn on/ turn off when we are doing stuff like loading a trailer, having coffee, etc. If I leave my tractor idling for an hour the clock doesn't change.
Does anyone have a link to a database that tells how different makes track time?
If I tracked time like my tractors do - only counting minutes operating at full speed - I'd probably still be a teenager
from the past:
2007
This is wrong. My B7610, made the same year of that post, counts hours based on PTO speed. here.The answer is different depending on what tractor you are talking about. Most models made in the last 10 - 15 years have electric hour meters that count clock hours anytime the engine is running, regardless of engine speed. Older tractors that had mechanical, cable driven tach/ hourmeters, counted clock hours only at rated speed. If rated speed was 2000 rpm, and the engine was running at 1000 rpm, it would register 1/2 hour for every hour run. Neither type needs to have wheels rolling like an odometer on a car.
You need to check for your particular tractor.
My 4110 is PTO speed hours. That is, it counts clock time only if I'm running at PTO speed. It counts less if I'm running at lower RPM. In a sense, it's counting engine wear, so people can do their maintenance based on the hour meter.
Cliff
On my M4700 turning the key off doesn't stop the tractor, I have to pull a lever (and push the same lever in to start it, before turning the key). I'm sure that I would have several hundred MORE hours on it if it counted all the time the key was in the "ON" position.My daughter has left the key turned on in my JD lawn tractor twice and it has more than 150 extra hours on the meter. It doesn't stop clicking until the battery dies. Luckily she doesn't drive my 5205.
A recent thread
<snip>
Is 4600 hours really THAT many hours? One thing I have noticed about this tractor is that the hours go up no matter what the rpms. If it idles for an hour it puts on an hour. If I mow at 540 PTO (2200 rpm) for an hour it puts on an hour. Seems like that hour mowing is much more wear than the hour idling. I'd say 95% of my work with this tractor has been below at low RPMs.
<snip>
