Bear Fence
   / Bear Fence #11
110 volts will do it in nicely. So will a 30-30. You have the right to protect your livestock from wild animals.
Someone in the US can correct me on this if I am mistaken.
@check; Where is your dump?
   / Bear Fence
I probably should clarify my "small calving bull" throws small calves, but he is big, in the 2000 lb range, became nasty and territorial this year. Not too worried about him or the heifers, just the trees. But to your point, I do have a gun in the truck when I go to that property (cougars also wander through from time to time), just never see the bear.
   / Bear Fence #13
Try just a little bit after dusk and leave the dog in the truck. Stick your nose in the air and if you smell something that smells like a over used outhouse then the bear is fairly close and upwind of you. They are basically shy and will try to avoid humans and dogs.
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2015 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2015 Ford F-350...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
