I went back and re-read the original post. I can't see what I am missing.
Is he not saying to the quote that it measures PTO speed not engine RPM?
The original post posed a simple question - are all hour meters the same?
Some measure hours based on "rated speed", meaning the time the tractor runs the PTO at 540 PRM. On my tractor (NH TN60A) this is 2200 RPM. Idle speed is 600 RPM. My tractor measures an hour base on an hour of run time. So, if I idle for an hour or run at rated speed for an hour the hour meter runs the same. Other tractors measure this differently. An hour at rated speed is an hour. Anything else is measured at less time. So if my tractor idled for an hour with one of these meters the hour meter would actually read 0.27 hours.
Another point of the original post was the question of how one can compare tractor wear if different brands measure wear differently. I use my tractor a lot in the winter for pulling firewood, logging, and feeding cattle. I start it up in the morning around 8:00, let it run all day (even during lunch because we are often below 20 degrees during the winter days) and shut it off at 5:00. That's nine hours on my hour meter. Let's say I average 800 RPM during that time (a lot of idle time while pulling cables and cutting trees and eating lunch). On a rated speed hour meter my hours would read 0.36 of what they do now. So my 4600 hour machine would actually read 1656 hours.
In my opinion the NH isn't keeping an accurate track of overall wear but of engine run time. But, when it comes to trade ins, no one seems to care about the finer points of hour meters. Thanks to the original poster for drawing a little attention to this issue.
As has been said before in this thread,,,, if the tach is cable driven it is geared to be accurate at PTO speed, which is where older tractors were expected to spend most of their time. If the tach is electronic, it is ticking once power to the clock is activated. It stops ticking when power to the clock is deactivated. No magic in either system.
My '84 Ford is mechanical. My '12 Kubota is electric.
I can run my Ford most of an afternoon doing piddly, idling chores and it might chock up an hour. The Kubota doesn't care, turn on the key and it'll clock an hour 60 minutes later.![]()
To further add to this, many meters are electronic and still are rated at PTO rpm, as if they were the old cable style. They take the rpm off a signal on the alternator or a signal on some sort of electronic pickup on the flywheel or other rotating device. Since it is pulled from a rotating part, they can still behave like a cable driven unit.
My 2001 Kioti DK 35 hours is based on engine speed. Near PTO speed for 1 hour= 1 hour.
I have often wondered about this also as my 2013 DK45 HST must register similar. Otherwise the hours do not match with actually engine running time.
I think it's based on the desired answer. If the manufacturer is concerned about recording engine revolutions they will install a pro-rated hour meter. If they are concerned about simply recording time that the engine is running they will install a simple electronic meter that starts ticking when power to it is initiated.
In regards to the Kioti, a simple test of turning on the ignition key and walking away for 30 minutes or so will answer which type it is.
Won't that tell us only whether it's time measured minute-for-minute whenever the ignition switch is on? I'm assuming that when, for example, Kioti claims they measure "real working hours" in the DK series, there is something more sophisticated going on. With modern computer systems, it could easily be done with software, and it would not need to be a straight linear relationship based on an increase or decrease in engine speed. For example, at below 1000 rpm, the software might be programmed to record at a rate of .25 hrs clocked per 1 hr elapsed. Between 1000 and 1500 rpm at a rate of .5 hrs clocked per 1 hr elapsed. Between 1500 and 2200, at .75 per 1 hr. Between 2200 and 2700 (or whatever full rated PTO speed is on the tractor), at 1 hr. per 1 hr.
Whatever approach a tractor uses to clock time, unless it's simply minute for minute the design engineers have to make certain assumptions as to what constitutes a "real working hour." It's those assumptions that I'm curious about. :scratchchin: It's just a curiosity. We could experiment by running the tractor for awhile at different rpms while measuring elapsed time against time recorded on the hour meter. But we'd still just be backing into the algorithm, and I'm not sure my need to know is all that strong right now. :laughing:
I've heard that hours on your tractor are not deducted from your life span,
Bruce
