What is the highest watt led light bar my L3240 can run?
   / What is the highest watt led light bar my L3240 can run? #1
4570Man
Super Star Member
Crossville, TN
Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
I'm looking to mount a led light bar on my L3240. I plan on getting the widest one that will fit in the bottom side of the ROPS and obviously mounting it on the bottom side of the ROPS with a swivel mount that will allow it to point forward or backwards. I'm probably looking at a 120-200 watt bar and just making sure it won't overload the electrical system. It will probably be used with the factory headlights on.
   / What is the highest watt led light bar my L3240 can run? #2
You could run up to 250 watts (20 amps x 12.5 Volts = 250W). It would be a continuous load, so the wiring needs to be at least 12ga. and on a dedicated, fused circuit off the battery.
   / What is the highest watt led light bar my L3240 can run? #3
Not the same tractor, but probably similar alternator output. I run a 108W tied right into the high beam switch, because the high beams are pretty much useless. No extra switch to deal with. No problems so far. Pics are low beam - high beam. I think the 108w is plenty.
   / What is the highest watt led light bar my L3240 can run? #4
   / What is the highest watt led light bar my L3240 can run? #5
Do you guys think I could get by with two 150 watt bars or should I back down to a 100 watt? One would be up front in the place of the factory head lights and the other on the ROPS.
   / What is the highest watt led light bar my L3240 can run? #7
Rigid original version D2 35 watts per pair silly bright. Best warranty and reviews I've found, very happy image-2320179489.jpg
Forward/rearward
   / What is the highest watt led light bar my L3240 can run? #8
100w LED will be more than enough light for tractor use, you probably don't even need that much.. Something like this should suffice..
https://www.superbrightleds.com/mor...vy-duty-off-road-led-light-bar-72w/1218/2859/
.. I run 150W off road on my jeep and that's plenty in the middle of a blackend trail in the trees...
FYI, save some $$$ and buy from Amazon... Amazon.com: 20 led light bar: Automotive
I've run plenty of these on my jeeps on the trails and fullsize and they are worth the money savings... Even if you had to replace in a few years still cheaper than buying the expensive ones.
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
2005 TerraGator 8104 (A52128)
2005 TerraGator...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
