No seat on bh 77
   / No seat on bh 77 #1
escavader
western maine
bx-23 ,
Thought it would have,but where my seat turns around on my tractor they didn't deliver with one I was looking forward to not having to reverse my seat.do you think it came with one and they just didn't put it on?mabey one of the dealers would chime in
   / No seat on bh 77 #2
Your post is a little confusing. Your bh77 has no seat. Or your tractor does not have a reversing seat?
   / No seat on bh 77
When I was watching videos of the bh 77 the operator had two seats hop off the one on the tractor step on tire right down into backhoe much easier than reversing the seat.my new b3300 came tonight when I reverse the seat I feel a mile away from the controls .wish the 77 had its own seat.What if I put the hoe on different tractor down the road then what?i want that hoe seat I saw
   / No seat on bh 77 #4
Ok
That separate seat is what would be on a cabbed model.
I really liked the room for the bh77 platform on my ex B3200.:thumbsup: The previous bh65 on my 2620 was really cramped.:thumbdown:
Can't you slide the seat close enough to make you more comfortable?
Have you talked to your dealer about a separate seat?
   / No seat on bh 77
Found tractor in drive last night havent talked to dealer.yet i seem to reach the sticks with seat all way back then again use to bx23 hoe hoping this last hoe i ever buy might go on different tractor who knows what it might be down the road .my post was to ask if dealers get these seats from kubota but just dont put on ?i certainly can build one if i have to
   / No seat on bh 77 #6
My BH77 has its own seat. I'm 6-2" and its cramped.
   / No seat on bh 77 #7
It's supposed to come with its own seat. If you Google "Kubota BH77", you get some pictures of what it looks like. The BH seat is back-to-back with the tractor seat, so your head is directly under the ROPS. They are pretty tight for space, so it helps if you're built low to the ground with short legs. Dealer probably has it sitting in the Parts Dept., wondering where it came from.
   / No seat on bh 77 #9
My BH77 on my B3300 doesn't have it's own seat and I don't want one either. It's an option to have the second seat, not just that the dealer 'forgot to put it on'. I'm 6'2" and have the seat set about mid-way on the slide tracks and happy with it in both forward and swiveled backward. I do a lot of quick stuff (like picking up a single rock) from the forward seated position with just reaching around behind me to run the controls. The flipped up second seat would all but eliminate this possibility.
   / No seat on bh 77 #10
I have a 3rd party hoe on my B2650 but.....is it possible that the mounting hardware for a BH77 is different depending on whether the tractor is equipped with a factory cab or is open station. The factory cab (which I have) necessitates that the hoe be equipped with its own seat and it would seem to me that the hoe on a cab model needs to extend further back to accommodate the seat and allow clearance to the back of the enclosed cab. Just a guess on my part but if the mounts are different then you (escavader) may have the cab mount hardware..Again just a guess.
8' X 24' DOUBLE AXLE UTILITY TRAILER FRAME (A51247)
8' X 24' DOUBLE...
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2014 Morooka MST1500 Crawler Carrier (A52384)
2014 Morooka...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
