Need a boom cylinder(s) for FEL
   / Need a boom cylinder(s) for FEL #1
CTWright
Santa Fe, NM
1959 MF65 Diesel and 1959 Ford 641 gas
I've been having trouble with my FEL since reinstalling it. The boom would lift extremly slow, if at all. After replacing the diverter valve and then the selector valves I finally found the problem. The right side cylinder was bent. The boom cylinder looks to be 2" ID and about 42 inches long collapsed.
c The attachment points are 1.5" diameter and cylindrical with a 3/4" hole for the pin. Aluminum threaded on ends and casing. Anybody know where I might find one (or two). No data plate so I have no idea what brand it is.
   / Need a boom cylinder(s) for FEL #2
A good local hydraulic shop could repair that by replacing the bent tube.
That might be worth a try. I'm not finding anything matching the pin ends and 40" collapsed length online except in Australia.
Found the cylinders that are on my FEL. Looks like a previous owner must have had access to an auto hauler as the cylinders are identical. Have the damaged one fixed locally by hydraulic shop.
   / Need a boom cylinder(s) for FEL #5
:thumbsup:
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53472)
NEW 2025 Load...
WB Mower (A50120)
WB Mower (A50120)
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
