MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
Needing some weld magnification at age 69 and wondering if a magnifier lens is available to fit this helmet?
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #2
I took a standard magnifier lens from the local welding supply(LWS) and cut/filed it untill it fit under the clips at each end. Be careful not to take too much off. And make the edges of the ends tapered to a sharp edge to fit under the clips in the helmet.
Do you mean the clips on the inside of the helmet? (shown in pic) I assume that the magnifier needs to go on the inside so as to not affect the lens darkening.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #4
Yup. Those angled pieces on the left and right of the window. They hold a thin protective cover. Remove that thin piece, and you can snap in a modified magnifier lens.
Use the thin piece as a guide to cutting your magnifier down to size.
Thank you for the info, Dan. Much appreciated.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #7
I just took a look at one of my helmets (forgot to get a pic) and it had a wire clip that was flexable enough to hold the thickness of a magnifier lens. But before that I had cut/filed a magnifer to just fit under the short edges.
If you take too much off ,like I did once, you can just tape it on.
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #9
I just wear my trifocal ANSI safety glasses under the Chicago hood. Works fine for me. Those glasses even have a top layer of magnification equal to the bottom. Real handy when working overhead on any project. Plastic lenses may be iffy when cleaning slag.
Ron
   / MAGNIFIER LENS AVAILABLE FOR CHICAGO WELDING HELMET #10
taped mine in.
Good idea. I used a 'bigger hammer' for fitting my Lincoln hood.
Carl (woodlandfarms), did you use transparent tape?? If not, what shade?
Terry
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2016 FORD F-150 (A50854)
2016 FORD F-150...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2006 TRAIL MASTER  DETROIT-TRIPLEX PUMP TRAILER (A50854)
2006 TRAIL MASTER...
