RV0313
I have two issues and I'm not sure if they are related.
Issue #1 When cold starting the engine the glow plug light doesn't illuminate, I typically just hold the Key for a few seconds and then start the engine without any problems. After the engine has run for any amount of time and I turn it off, when I go to start it again the glow plug light comes on as if the engine is cold. This happens all year long winter or summer, I know in the winter the engine is cold but the glow plug light doesn't come on. Not really a problem as I haven't had any trouble starting the engine it's just annoying.
Issue #2 when traveling in II gear Hi speed the slightest incline causes the tractor to bog down and barely will move. This happens on the slightest incline in a field or on pavement with out any attachments on the tractor. I gear and low speed seam to work fine.
I've changed the oil and filter, both air filters, fuel filter and the fuel pump none of which have seemed to help.
I've been having these problems for over a year and haven't been able to figure out their cause.
