How strong would channel iron be if ?
   / How strong would channel iron be if ? #1
aldanbnb
Battle Ground In.
Same, Gravely, Wheel Horse
Hi
This is going to sound a bit odd but,
What I have is a bent Bobcat attachment plate that I have straightend.
To keep it from bending again I am going to try welding a couple of pcs. of 8" x 1/4" channel on.
If I weld the legs to the flat plate how strong is that going to be ?
I was wanting to use 4" x 1/4" square tube but cannot find any used cheap. That would have been as strong as I need, I think.
Thanks
   / How strong would channel iron be if ? #2
I think you may be missing a dimension on the angle iron. Are the pieces 8" long by 1/4" thick? What is the width of the angle iron?
   / How strong would channel iron be if ? #4
Channel, not angle.
My mistake. If 8" wide channel and 1/4" thick this would be standard grade not structural grade. It would add strength to the flat bar more than double the flat bar alone.
Thanks guys
COUNTYLINE SUB SOILER (A57192)
COUNTYLINE SUB...
3ft Metal 5-Point Star (A55853)
3ft Metal 5-Point...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
New Holland TC21D (A53317)
New Holland TC21D...
GROUNDHOG ZH12G EXCAVATOR (A57192)
GROUNDHOG ZH12G...
1981 LOAD KING BELLY DUMP (A53843)
1981 LOAD KING...
