In search of tool for hard to reach hydraulics
   / In search of tool for hard to reach hydraulics #11
Yep! Crowfoots.
images
images
Thanks all. I will try the crows foot wrench.
   / In search of tool for hard to reach hydraulics #13
You really want a crowfoot flarenut wrench. It's the wrench on the left in Mace's posted pic. A straight crowfoot is likely to round the corners of the fitting. Unlike a nut, there is very little metal to resist crushing.
   / In search of tool for hard to reach hydraulics #14
One of the above ideas my work but here is another:
I have a set of both metric and SAE flare nut wrenches. In the past I have modified and shortened them to get into tight spots. here is a HF link. At the price you can afford to modify. Crow feet work a lot of places but the handle type may get in better with more leverage.
Search results for: 'flare nut wrench'
Ron
   / In search of tool for hard to reach hydraulics #15
I agree with this assessment. Though it may be necessary to use an actual crowfoot wrench instead of just the wrench end on an extension. AND you will likely need to get the cylinder to where you are able to get another wrench on the next piece of the assembly. Usually it takes two wrenches to break something loose like what you showed in your pics. Each section is tightened against the next until it's all tight. Wouldn't be a problem but the hose will only allow turning so far and then it will jam. Better access to the fittings is your best solution.
2015 International DuraStar 4300 Johnston VT651 Street Sweeper Truck (A50323)
2015 International...
2017 Ford Escape SUV (A50324)
2017 Ford Escape...
2020 CATERPILLAR 308CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
