Kubota L3400 --Water in Hydraulics
   / Kubota L3400 --Water in Hydraulics #11
Thanks for the correction BUT it's still very important that breather hole isn't plugged no matter where it is located so moisture in oil reservoir once it's heated from operation can evaporate
   / Kubota L3400 --Water in Hydraulics #12
That and if it is plugged with a No.8 screw it will blow the dipstick out on the ground if you lower the FEL lift (on models like my Kioti that have a dipstick, I realize the L3400 does not). Don't ask now I know that.:eek::)
   / Kubota L3400 --Water in Hydraulics #13
Just wondering if a good diesel filter, one that separates water, could be used on the drained hydraulic oil, so you could re-use it after filtering? That's if it is still good, aside from the water?
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
2000 INTERNATIONAL 4700 (A52472)
2000 INTERNATIONAL...
LOT LOCATIONS (A52576)
