Tips, tricks or any info on new to me dk40se hydro
   / Tips, tricks or any info on new to me dk40se hydro #1
Orange blood
Member
Tennessee / Chattanooga
2014/15 kioti dk40se hydro
Got the tractor yesterday (10/6) just looking for info to help a rookie out. What are the musts to have in the tool box ? What xtras do u carry for possible in field repairs is there a checklist for stuff to check and or lube before use thanks
   / Tips, tricks or any info on new to me dk40se hydro #2
The best tip IMHO is to actually read your manuals and buy a quality grease gun and use it.
   / Tips, tricks or any info on new to me dk40se hydro #3
I carry an adjustable wrench, and hitch pins. Anything more severe than that requires a trip back to the shop.
Thanks the guy did not bring the manual back when he traded but they said they knew him well and would call but just in case they ordered me one right then . I will definitely be reading it just wanted some info til I get it
   / Tips, tricks or any info on new to me dk40se hydro #5
Grease, grease and grease again. Did I mention grease? No kidding, every time I use my loader I grease it. The book says every ten hours, but I am the guy that has to fix the loader pins if they break, so I pound the grease to them. It might be a waste of grease, but it is a lot cheaper than replacing pins.
   / Tips, tricks or any info on new to me dk40se hydro #6
CHeck and ensure all loader/sub-frame/backhoe and wheel bolts and lugs are tight. Keep everything greased and read and understand the owners manual!
I don't carry anything besides an adjustable wrench/screwdriver and a vise grip and some extra hitch pins in any of my tractors.
Good choice with the DK its a well thought out machine and its a work horse to say the least.
   / Tips, tricks or any info on new to me dk40se hydro #7
Congrats on the tractor! If you bought it used, I'd go ahead and change all fluids and filters. And like a couple of others have said; hit all the zerks with some grease.
Since I don't have manual yet when is next service after 50 hrs and what is changed ? Thanks
   / Tips, tricks or any info on new to me dk40se hydro #9
Always make sure the lever to lock an implement onto the QA'a is in the locked position before lifting the loader. If you get in the habit of doing it before you might get distracted and possibly forget, it will keep you safe of an implement dropping off when lifted. I use a Bungie now too, to make sure I lock it and 'suspender' it, since I did forget recently, and could have dropped my 400# grapple on myself. I'm going to make a sign to attach to the grapple to tell me to check the lock so I see it when I get on the tractor. It only takes once missed, we don't always get second chances.....
Enjoy the tractor. take it slow. Use medium for most work, low for hard slow work and High for travel on the road. 4 x 4 for most where extra traction is needed, (engage BEFORE moving), and locking diff, in a straight line only, when spinning wheel(s) in 4 x4 for last ditch to get out of same. Keep center of gravity low and look at the loader when lifting; don't continue lifting if backing up, or with full bucket of anything. Keep loader bucket as low as possible to maneuver a load and no sharp fast turns.:thumbsup:
   / Tips, tricks or any info on new to me dk40se hydro #10
100 hrs service
engine oil
grease
Check engine start system
Check Wheel bolt torque
Check battery condition
Clean air cleaner element
Clean fuel filter element
Check fuel line
Adjust fan belt
Adjust clutch
Adjust brake
That is all that is in my manual for the CK25/27/30/35 I doubt the DK40 would be any different
New/Unused 9.5ft 30 Drawer 2 Cabinet Workbench (A51573)
New/Unused 9.5ft...
EZ-GO Electric Golf Cart (A50121)
EZ-GO Electric...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52748)
Adams FL24...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2025 AGT SSFM81 Hydraulic Drum Mulcher Skid Steer Attachment (A50322)
2025 AGT SSFM81...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
