my kubota L3400 lost power
   / my kubota L3400 lost power #1
liljoe
toms river nj
kubota L3400
i need some help we thought maybe gas was put into tractor so I drained and put new fuel. now tractor wants to start but will not. I also changed the oil but no start. does anybody have any idea what I can do?
   / my kubota L3400 lost power #2
More details would be helpful. My first guess would be plugged fuel filter.
if I turn key back and heat glow plugs it starts then shuts off.
also you can see smoke coming out of exhaust while its cranking,could it be bad glow plugs we never changed them
   / my kubota L3400 lost power #5
Possibly plugged filter as mentioned. Or air in the lines.
What made you think gas was put in it
   / my kubota L3400 lost power #6
Exhaust smoking could be gasoline mixed in with diesel. Had an employee do that to one of my diesel trucks once. It ran, but made prodigious amounts of white smoke and the engine didn't sound real good either. Drained it all.
it happened once before this tractor is used at a campground by 4 different guys, they call me when there is an issue. the message was tractor lost power my first thing was to check fuel for abnormal smell and I smelt gas so I drained the tank and changed the oil then put fresh fuel in tank tractor wants to start but will not. if I turn key back to heat glow plugs it starts then stalls
   / my kubota L3400 lost power #8
There is alot of fuel still left in the system that draining the tank likely didnt remove
   / my kubota L3400 lost power #9
may have put gas with water in it,change fuel filter then bleed air out. pure gas wouldn't cause low power it will make a diesel scream and it aint good for one
   / my kubota L3400 lost power #10
Not sure that's true.
If I remember right we had a member a while back that lost power.
He had put gas in his fuel tank.
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
2013 FORD F-650 ROUSTABOUT (INOPERABLE) (A52472)
2013 FORD F-650...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2015 Cadillac ATS Sedan (A51694)
2015 Cadillac ATS...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
