Traction 4200 Hydrostatic positive lock won't engage completely
   / 4200 Hydrostatic positive lock won't engage completely #1
simonds
Steuben Co. N.Y.
John Deere 4200
1999 JD 4200 hydrostatic. Positive lock differential petal won't lock in completely. I can feel it going in and out while holding the petal down. I don't find any adjustment on it. Any help out there? Thank you.
   / 4200 Hydrostatic positive lock won't engage completely #2
Look at the linkage on jdparts.com and see if you can decipher where the problem might lie. Might be something broken.
   / 4200 Hydrostatic positive lock won't engage completely #3
Here are the two breakdowns from JDP, if you can "feel it going in and out" then I'm afraid it might be internal.:
4200-1.gif\
Thank you for the replies. I'll check it out further.
   / 4200 Hydrostatic positive lock won't engage completely #5
I just started tearing into my 4300 to fix the diff lock. I bought it that way and from what I'm told the lock itself is a cast piece which is prone to breaking if engaged after one wheel is already spinning. A school had used it to plow sidewalks so it probably did a fair bit of spinning if the new guy forgot to engage 4x4. The pedal moves fine but doesn't do anything. The part is between $100-150 from memory, but lots of hours to replace it. According to the manual have to remove the right final drive and the 3 point rock shaft assembly. Hoping to get the old one remove this weekend, can let you know how it goes.
   / 4200 Hydrostatic positive lock won't engage completely #6
One side of the diff-lock mechanism is soft cast steel; the other is harder/tougher steel.
So the former wears a lot when rubbing against the latter. If there is enough meat left
on the cast part, then you can shape it with a grinder to make it grab better, as I
did for one of my 4300s.
Otherwise, you are gonna have to buy the whole ring and pinion set. $$$$
   / 4200 Hydrostatic positive lock won't engage completely #7
Wow, great pics! I'm assuming you're holding a new piece in the second pic? What did the original one look like?
   / 4200 Hydrostatic positive lock won't engage completely #8
That IS the original piece. I just reshaped it with a die grinder and an angle grinder.
   / 4200 Hydrostatic positive lock won't engage completely #9
I mean the smaller piece in your hand in pic 2 (not with the arrow), it looks like you ground the ring/pinion side.
   / 4200 Hydrostatic positive lock won't engage completely #10
Yes. Only the part attached to the ring gear was reshaped. It was an error on JD's part to use
such a soft steel as part of the diff-lock dog clutch.
It seems to work OK after this repair. No new parts were purchased.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A50323)
2009 Peterbilt 384...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
New Holland TS6.120 4WD Agricultural Tractor (A50322)
New Holland...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
Fork and Frame Skid Steer Attachment (A49462)
Fork and Frame...
