Backhoe bucket under warranty?
/ Backhoe bucket under warranty? #1
moparrob
SW Idaho
2008 Kubota M59
Hello- have any of you had a broken bucket replaced under warranty? I've been waiting about a week to hear if it will be covered. I can weld it and reinforce it, but I'd rather get it replaced, since I bought the tractor mainly because of the warranty. Meanwhile, my project is at a standstill and winter is fast approaching.
Thanks in advance for any feedback!
/ Backhoe bucket under warranty? #2
Curious....what broke?
/ Backhoe bucket under warranty? #3
Surprised that the bucket would break. Was it a light duty bucket?
The bucket is the 12" that came with the tractor. It started with a crack between the teeth and then the cast or forged piece which the teeth attach to completely busted apart, tearing away from the thin sheet metal the rest of the bucket is made from. If i fix it myself, i'll definitely weld more material (probably 1/4" plate) onto the rest of the bucket. I hope they let me keep the broken bucket so i can make a custom bucket later.
/ Backhoe bucket under warranty? #5
"sheet metal" ?
/ Backhoe bucket under warranty? #6
I've got the same loader/bucket as you and I can't imagine it breaking or calling it sheet metal.
Did you hook it on something immovable or something?
The bucket bottom and back appears to be made of very thin steel, welded to the casting which holds the 3 digging teeth. I was digging in rocky soil, but I wouldnt think the hydraulic forces are that strong considering the relief valve setting.
/ Backhoe bucket under warranty? #8
Your hydraulics should stall out before the bucket breaks. I would say it is a warranty issue for sure and maybe ask for a stronger built bucket.
I'd guess that the thin steel is about 1/16" thick, so maybe not sheet metal, but definitely thinner than I'd build it.
/ Backhoe bucket under warranty? #11
Better get the dealer to move on it because I think the back hoe only has a 1 year warranty. Check it out to be sure.
/ Backhoe bucket under warranty? #12
Your definitely in a grey area. The bucket is covered for manufactured defects, But????. Get your dealer and dealer DSR involved.
/ Backhoe bucket under warranty? #13
I will hold back comments til I see a picture??
/ Backhoe bucket under warranty? #14
I did not break my bucket
I doubt your hoe could not lift an 8,000 Lb. tractor front end off the ground.
All kidding aside, any machine should not be able to hurt its bucket, maybe snap a tooth, that is about the limit.
/ Backhoe bucket under warranty? #15
Re: I did not break my bucket
Under normal use...
But things get abused. Like using the bucket as a hammer to break concrete? Or swinging sideways fast and hitting a pile or tree...
Things happen. Machines arent designed for that and are examples of how they can easily break something
/ Backhoe bucket under warranty? #16
As someone mentioned, if there is a defect in material or workmanship it will be covered as long as you are still in the warranty period. Having said that, the buckets are sort of light for the power the backhoe has. Yet we have sold a ton of these, and bucket issues are rare. No problem in most circumstances, but in heavy rock or doing demo work I can see how you could mess one up. I like your idea of reinforcing it. If you do that, let me recommend that you install tooth holders like you see on a mini-excavator, as opposed to the crimp on style. Easier to change, they last longer and are widely available. Then weld some straps on the bottom and you will have a heavy bucket. I'd add a pin bushing on the opposite side also. As far as I know, Mahindra does not offer a heavy duty bucket on that model. Rarely will anyone ask for a heavier bucket unless they come from a commercial operator background and are used to heavier machines.
Thanks for your input and advice! If Mahindra does warranty this, will they let me keep the broken one? Of course, this broke in the middle of a job, and I'm waiting for an answer from Mahindra when I could have welded the darn thing and been back to work!
/ Backhoe bucket under warranty? #18
The failed bucket will have to be returned to the dealer, as Mahindra will probably want it back to inspect. Often they want to see what happened, and to do that requires an inspection. But you could ask, and the dealer could see if he can get the OK from Mahindra for you to keep it. That would be nice, as it in a small way would help you feel better about being out of commission for a few days. Generally speaking though, you cannot keep the failed part.
/ Backhoe bucket under warranty? #19
Such an awesome picture !! I don't think my B21 can do that.
/ Backhoe bucket under warranty? #20
Off subject, but after years and years of no issues, I can no longer see most of the attachments on TBN. Like the one a few posts above, it tells me there is an attached thumbnail, and then the little black box with an X in it. My system issues I suppose as I do not see anyone else complaining about it?
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2018 BOBCAT T550 SKID STEER (A60429)
2018 BOBCAT T550...
2021 Deere 333G (A53317)
2021 Deere 333G...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
