Special Engine Oil with DPF???
   / Special Engine Oil with DPF??? #1
Mlebout
Member
Gaspe, QC
MF 1736HL
About to do my first oil change, on my 1736HL, however manual says to only use oil specified for DPF. Not sure if this is just MF's way of selling more oil or not? Can anyone advise me if regular SAE 10W30 or 5W30 is sufficient?
Thanks,
Mike
   / Special Engine Oil with DPF??? #2
Any of these oils 5W30,5W40,10W30 can be used. Just read the label and make sure its oil rated for diesel engines. Most all diesel rated oils sold in stores meet current specs required by tractor manufacturers. The ones with 5W will be better for cold weather starting.
Thanks for the quick reply George!
   / Special Engine Oil with DPF??? #4
Oil standards change every few years. The amount of ash content in the oil generally gets lower with each oil. Tthe last change was in 2007 or so and the oil is designated as CJ oil. DPF systems were designed to work with oil that has meets CJ standard - other than that, pick a weight (30 wt, 5W20, etc...) that says works for your outside temperature range anf your are off to the races. Its getting harder to find but is possible to find some oil that has a meets the older CI standard - it generally costs less and is available in bulk only.
Thank you!
   / Special Engine Oil with DPF??? #6
Rotella T6 5w-40. Meets or exceeds. Not expensive and easy to find in most autoparts stores. Used extensively in motorsports and high temp / turbo applications. Not only for tractors. Plus great oil analysis results can be found on BITOG forums.
Thank you Rotella!
   / Special Engine Oil with DPF??? #8
Just curious what def exhaust fluid is?
   / Special Engine Oil with DPF??? #9
Yes you MUST use an oil formulated for DPF it;s normally stated on the label. Maybe a google search will give you several choices
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
(3) Goodyear 480/80R38 Tires (A56469)
(3) Goodyear...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
UNUSED PABREAK VR720 - 74" VIBRATORY ROLLER (A57193)
UNUSED PABREAK...
John Deere Z540M (A56469)
John Deere Z540M...
