Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #2,261
Do you have any idea what that wood box weighs? Do you think my LA724 loader could lift it?
   / Tractors and wood! Show your pics #2,262
and move it to my basement window,
When I was 8 or 9 years old a burglar broke out a similar window to enter our house and rob us blind. All the others were alarmed because of a similar break in two years before. Just curious if you take any precautions?
   / Tractors and wood! Show your pics #2,263
a half cord of green maple weights 3000 lbs. better check the loader specs. I would say about 2000 is about the limit not to mention the danger of tipping the tractor with all that weight out front. I own a L4740 and it is unstable when raised high to load a truck with 1/4 of a cord. I have loaded tires and a logging winch on the back.
   / Tractors and wood! Show your pics #2,264
I like that idea using the window. I need to do something similar as my wood.coal furnace is in the basement as well. What kind of furnace do you have?
My kids would not agree with you at all :D
From the time they were 5 and 7 it was their job to push the wood thru the window over a little plywood ramp after I dumped it a wheel barrow at a time. We did hundreds of cords that way over the years.
A tractor and wood shed are life changing things !
gg
   / Tractors and wood! Show your pics #2,265
Looks like a good job for a set of rear forks combined with TnT to leverage your tractors ability to get it done.
   / Tractors and wood! Show your pics #2,266
   / Tractors and wood! Show your pics #2,267
Proper ballast will fix that problem. My loader is probably not strong enough to lift it especially since my firewood is oak. My 3PH lifts 3,700 pounds, so rear forks should lift it.
   / Tractors and wood! Show your pics #2,268
The window is steel frame with center bars, that locks from the inside. It also comes out for putting wood in...
SR
   / Tractors and wood! Show your pics #2,269
What is the TnT leverage you mentioned?
   / Tractors and wood! Show your pics #2,270
I have a potential project here. This forklift mast would look real good sitting on my tractor's backhoe subframe.
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
Hydraulic Coupler 80 mm Pins (A52384)
Hydraulic Coupler...
