Anyone move round bales with a L3800?
   / Anyone move round bales with a L3800? #1
gsganzer
Elite Member
Denton, TX
L3800 w/FEL and BH77, BX 2200 w/FEL and MMM
Anyone use their L3800 (or L3901) to move round bales with a FEL bale spear or a 3-pt spear? I'm not planning to move them far, just unload from a flatbed and put out in a feed ring, traveling over flat ground.
   / Anyone move round bales with a L3800? #2
You had better get an idea of their weight.To many different sizes/weights to offer a guess.
   / Anyone move round bales with a L3800? #3
I move fescue/rye rounds that weigh less than 1,000 pounds with my little JD870. It uses the same size tires as a L3800. If I had known I was going to move round bales, I would have bought a bigger tractor. Off the trailer they go, down to a few inches off the ground. Never lifted back up unless I am on my concrete aisle. If you are buying a tractor, go bigger. If you have a tractor that small, you can do it if you are careful.
   / Anyone move round bales with a L3800? #4
I move round bales all the time on the 3 point with the l3400. With the loader I could do it, but why bother when my jd handles them 2 at a time comfortably on the loader.
   / Anyone move round bales with a L3800? #5
You shouldn't have a problem as long as you have proper counter-balance hanging off your 3PH, keep the load low & slow. A 2 spear minimum on your FEL will keep the round secure.
My 4105 has just a few more horses under the bonnet and haying season starts in about a week (rounds, silage is going on now)... I'll be out helping with my rig, gathering and then loading the flatbed. No problems at all.
   / Anyone move round bales with a L3800? #6
My neighbor has an L2550 with a 3 point bail spear. Has no problem moving them around.
   / Anyone move round bales with a L3800? #7
We have a L3200 (slightly smaller) I havent seen the loader specs, but it looks like it could handle it, i would have plenty of counterweight though.
   / Anyone move round bales with a L3800? #8
Here's the loader specs. I have an L3200 and I think I'd be pretty close once you get that far out and depending on the weight of the bail. It'd be a pain to grab a wet one and have no way to move it
   / Anyone move round bales with a L3800? #9
Depends on the size of the bales and desired lift height, it should work on the loader. It will definitely work on the 3 point hitch. Here is 1,000 pounds of concrete on a L3800. image-3330120186.jpg
   / Anyone move round bales with a L3800? #10
So i suppose it could, just be on the limit.
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2020 ISUZU NQR BOX TRUCK (A58214)
2020 ISUZU NQR BOX...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
