Snow Blower now Loader Mt'd
   / Snow Blower now Loader Mt'd #1
Balerguy2
N. Illinois
L4610 GST/ LA 852 loader, GrassHopper 725DT
I am now beginning the 3 rd winter after moving the PTO 3PH snow blower to hydraulic drive mounted 4 PH on the LA-852 Loader. Just a couple days ago we got 16" of snow over night. Blowing Snow going forward is clearly more fun! My "Mule" is a 14 year old Glide Shift Kubota L4610 with a "pin on Loader" (bought new in 2001). I have chains but don't use them and "no load" in the tires. The "chute" is moved via a 50 dollar 12 vdc winch. Simple and reversible instantly and very strong.
Every now and then some questions about fabricating DIY or locating an OEM setup like this pops up here on TBN. This is just an effort to help some one understand the concept. I used 3/4" for HP & LP lines ie (one each) and 3/8" case drain. No QD on these lines and the only valve necessary is Pressure Relief. My mule has an over running sprag clutch as OEM and to turn the snow blower on is simply sliding the PTO lever to "engage". I don't know how it could be more simple.
Some design & fabrication info: http://www.tractorbynet.com/forums/hydraulics/286706-pto-snow-blower-hydraulic-drive.html
I had some steel and the Hyd. Power Pack 3 PH Rack mount plus the 3 PH Snow Blower. Hydraulic fittings, cast iron Prince 21 gpm pump, Tank & Motor all came from Surplus Center, Lincoln, NE. Hoses from Discount Hydraulic Hose (DHH) Philadelphia, PA.
   / Snow Blower now Loader Mt'd #3
I bet your neck is happy!
Nice job and thanks for bringing your original post back. As much as I'm "on here", I still miss some good posts of projects.
Farmer495
Rustyiron
Thanks for the good comments.
Balerguy2
   / Snow Blower now Loader Mt'd #5
Very nice!
   / Snow Blower now Loader Mt'd #6
There is only one thing I don't like about your setup is your plastic windshield. As the inside of the cab warms up, the snow swirling outside will begin sticking to the plastic. The simplest solution is to give the plastic a hard rap with your fist.
   / Snow Blower now Loader Mt'd #7
I remember that post. Very impressive job.
And I like you chute deflector control...haha. We dont need no stinking chute deflector controls.
Roy
smfcpacfp
GPintheMitten
Thanks guys for the good pointers! I used this blower about 20 years ago on the front of my skid-loader. It was great in the arc of the wiper but not so good else where! I'rd break up a steel/glass cab in the woods pretty quickly. The best I can do (winter time)is the CMT enclosure and it works really well. Heat? I use electric heated (12 vdc) clothing that I have designed and made for motorcycling. Turn the 12 v on and I am toasty warm although when the sun is out that cab heats up and I have to slide one of the doors open.
The 12 vdc winch control is push button L or R and can rotate 240 degrees. Works really well and costs dirt cheap. Simple and it is easy to wind the cable on the drum so it will pull in either direction instantly. One of these days I'll do a vertical deflector! I still have the temporary ties and bungie(s) put on as I proto typed the build! Good for me .......... a new production loader mounted front snow blower costs 3 times what mine has cost.
   / Snow Blower now Loader Mt'd #9
How do you move the chute the other way with the winch?
A 2 way winch can wind 2 ways by winding "clockwise" one end of the drum and running to the chute & fasten*. Take the remaining cable and wind to the other end of the drum "counterclockwise" 1 or 2 turns and then run to the chute(circling the chute 2 or more times) and fastened.
Note this is 1 cable ie one single cable that is divided about 50-50 at the winch drum...... and wound as described.
So now pressing either In or Out on your controller the cable pays out from the bottom of the drum and winds onto the top of the other end of the drum. And, vice a versa. Voila! If it is going the wrong way just reverse the power + & - leads and the winch motor will run the other way and correct your problem. HTH!
*Have the chute outlet set at 12 oclock (ie straight ahead) or 1 oclock which will allow control 90 left and over 100 + to right. Don't fool with hydraulic or electral/hydraulic actuators. They are costly and complicated. A powerful winch is 50 dollars at Menards or similar store.
You use a 45-70 rifle?
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
2284 (A58376)
2284 (A58376)
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
Deer Target (A57149)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
