What degree of gasoline/diesel contamination is permissible?
   / What degree of gasoline/diesel contamination is permissible? #1
Retiredguy2
Gold Member
Michigan
Deere 4410
I have about 8 of the older Chilton type 5 gallon cans, and transport both gasoline and diesel in them. Sometimes I want to run for diesel fuel but the only empty cans are marked "gasoline only" and of course it is next to impossible to drain a can dry...do I really need to worry about a half ounce or so of gasoline left in the can when I refill it with diesel, and vice versa when diesel can is almost empty and I need to refill it with gasoline? Thank you for your input.
   / What degree of gasoline/diesel contamination is permissible? #2
A couple tables spoons, the amount that usually is left after you do your best empty job on some cans, is not going to hurt anything. I would be more worried about water or rust or stuff like that. You are not going to blow up your diesel with a half an ounce of gas mixed with 5 gallons of diesel. You can actually run a diesel on a mix of gas and diesel.... once it is running. [[[ I have done this, not on purpose.... :) ]]] Just can't start or idle it with a mix....
   / What degree of gasoline/diesel contamination is permissible? #3
I wouldn't be as worried about that small amount of contamination, as I would about someone (me) forgetting that there was diesel in the gas can, or gas in the diesel can.
Good advice, but I always clearly mark the contents of any can. One of the issues is some of the Chiltons I have are red and some are yellow !!!! And BTW I treat fuel I expect to store longer than 6 months with both Sta-Bil and gasoline antifreeze. It all goes through a premium funnel before into a fuel tank for final burning.
   / What degree of gasoline/diesel contamination is permissible? #5
Tankers that haul fuel have a little gas left in them when they go back and take on a load of diesel. No problem.
   / What degree of gasoline/diesel contamination is permissible? #6
Read the operator's manual of some Diesel engines . They promote mixing 30% gasoline at -40F.
   / What degree of gasoline/diesel contamination is permissible? #7
At -40 I recommend staying indoors and throwing another log on the fire ;)
   / What degree of gasoline/diesel contamination is permissible? #8
Somebody accidentally pumped a couple gallons of gas in my truck fuel tank but I filled the rest with 30 gallons of diesel to top it off. Worked fine, but I was worried. I put miles on to lower half a tank and then refilled it again. It gets diluted pretty well. Note to self; Be alert and not angry with the wife when filling the truck.
   / What degree of gasoline/diesel contamination is permissible? #9
Nothing that has been made this century. And we still didn't mix gas in with diesel at -55F when I lived in Alaska. Just pretty much #1 and additive.
   / What degree of gasoline/diesel contamination is permissible? #10
You can run a diesel engine with up to 10% or so gasoline, but the vapor space in the tank can then be explosive (if ignited); whereas, the vapor space in a gasoline tank is too rich, and the vapor space in a diesel tank is too lean. Back in the 80s, Benz was advocating up to 10% gasoline to reduce the cloud/pour/solidification point of diesel in the winter. I did it in our old 220D. Luckily the tank didn't get an ignition source.
A little bit of either in the other doesn't matter.
Just clearly label your cans if they aren't the right color.
Ralph
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2014 CATERPILLAR 299D SKID STEER (A52705)
2014 CATERPILLAR...
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
2024 TIMPTE HOPPER 43FT HOPPER TRAILER (A54607)
2024 TIMPTE HOPPER...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
