Portable Air Tank
   / Portable Air Tank #11
Thanks for the follow-up. That's a weight he should be able to handle happily. :thumbsup:
But that's empty weight. What about after he adds 120 lbs of air?
   / Portable Air Tank #13
I'm told that an aluminum SCUBA tank will sink after being filled to 3500 psi.
A scuba tank as way overkill unless you put a regulator on it, and use 3000 psi in the tank. An 80 cubic foot scuba tank weighs 40 pounds empty. They will sink, but only to a certain depth.
   / Portable Air Tank #14
Check out power tank. Co2, fills tires fast can run air tools etc. I fill mine at welding shop.
   / Portable Air Tank #15
Why are the tires going low all the time?? Help him out by getting the tires fixed!
SR
   / Portable Air Tank #17
120 lbs of helium may be easier to lift.
It is very little difference in a compressed tank. I know a 220 cubic foot steel tank is pretty darn heavy full of helium or oxygen. Helium has thinner molecules than air making it a poor choice to fill an already leaking tire with.
   / Portable Air Tank #18
I'm not sure how expensive they are to fill, but something like this could work.
   / Portable Air Tank
SR
Now that is a good question. The tires need air about every few months maybe 5 lbs. and up to to 10 lbs every 6 mo. The older tires need air more frequently than the newer tires. I thought this was normal, is it not?
How often do all of you check your tires and do they ever need air?
   / Portable Air Tank #20
I like that use of space and no lugging. That is a good idea! But I just ordered the HF aluminum tank yesterday and he already has steps. The price at $550 seems reasonable if you have more uses for the air than he does.
Late reply, but yeah the only way i'd justify the price is "well, doctors visit for hernia is cheaper than $500" Thats kinda how it's getting with my parents now "Well, paying a guy to do this, is cheaper than one of you falling off a ladder since I can't always come over"
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2001 Club Car Electric Cart (A55853)
2001 Club Car...
22ft Rollback Flatbed Body with Winch (A54814)
22ft Rollback...
Red Military Truck (A53422)
Red Military Truck...
