Tires 2005 CK30HST front stock R1 Ag tires tubes or tubeless?
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #1
mrutkaus
15 mi. N. of Winchester VA
Kioti CK30HST, Kubota BX-1500,
are they tube or tubeless, got a strange leak...
For that matter, what about the rears R1 Ag tires?
thanks
mike
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #2
thanks
mike
Unless someone put a tube in them, they are tubeless. You should be able to look at the valve stem and tell for sure.
yep thanks, memory loss here
mike
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #4
I think if your rear tires are loaded then they are tubed. Not sure if any tractor comes tubeless.
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #5
My tires are all tubeless and the back tires are loaded.
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #6
Tubeless is the norm.
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #7
Same here.
My R-4 tires are all tubeless and the rears are loaded with windshield washer fluid
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #8
My 2006 CK30 HST came (new) with tubes fitted and rear tyres loaded. (Ag Tyres)
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #9
Next time that I am near my tractor 2013 CK30 HST I will check to see if they are tubeless or not. Cause I am now curious lol.
   / 2005 CK30HST front stock R1 Ag tires tubes or tubeless? #10
Look at the tire side wall. It will usually say tubeless if they are.
Most R4's are tubeless unless someone put tubes in.
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
Contender Diamond Plate Toolbox (A51573)
Contender Diamond...
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
