Welding exhaust pipe right off the manifold
   / Welding exhaust pipe right off the manifold #1
Gary Fowler
Super Star Member
Bismarck Arkansas
2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
The header pipes off the manifold on my RV broke off on one side due to an impact with road debris. I welded it back up using oxyacetylene torch and ER70S-2 wire but the welds really didn't like to fuse with the parent metal. Since it is right off the manifold, I suspect it is a chrome alloy of some type. It isn't stainless for sure but the mild steel electrode didn't want to fuse real weld and the inside of the pipe would "sugar" a bit after welding which tells me it must be 5%or more chrome content.
Anyone have any best guesses as to what kind of material the exhaust piping is made from.
   / Welding exhaust pipe right off the manifold #3
Newer exhaust could be that new automotive 409 Stainless. It doesn't act like stainless at all. Not sure what you have but brass brazing could work. Not sure how it will take to the heat and vibe. Maybe a 3/32 or 1/16 stainless stick would be better.? You could look for some of that MG Easy Strike 1/16. or Mig it. If you have a close fit up, maybe silver solder with a little nickel in it like 50N. Strong and ductile.
   / Welding exhaust pipe right off the manifold #4
I had to make very short 90* bend exhaust pipe that came right off shorty headers on a street rod I had. On ready made 90's available in auto parts stores the sweep was too large and I didn't have frame clearance. Nobody makes a real short sweep 90* so I made my own. I cut the pipes to the size I needed and used oxyacetylene and coat hangers to braze together. Just had to get the pipe cherry red and flow the coat hanger in like solder. Worked very well.
   / Welding exhaust pipe right off the manifold #5
Yup, usually 409. Has a dull finish and will show rust stains.
For sure could be a low grade of stainless since it only had a light coating of rust and dirt that I sanded off. It did require a lot of heat to fuse the ER70S-2 wire to it and did see a light oxidation (sugaring )inside after welding.
I have already completed the welding with the carbon steel rods so advice as to the right rod to use would just be informative for later use. I have welded SS with 7018 rods a lot of times with good results as far as fusion and strength (not breaking later) but never tried it with gas welding.
I guess now I will just have to wait and see how it goes with the weld. If it breaks again, I will have to have a muffler shop make this short portion and then weld it onto the original pipes which is what I started to do this time but decided to just weld it up and see what happens.
How well did the fabrication hold up?
   / Welding exhaust pipe right off the manifold #8
My buddy that used to do exhaust always just used 70s wire in his mig. I never heard of any complains from anybody, so I guess it worked just fine.
   / Welding exhaust pipe right off the manifold #9
I brazed up that exhaust system 7 years ago, sold the car 3 years ago, Saw current owner this past summer and exhaust is still fine. No leaks. I did paint the pipes with hi temp alum. paint when done.
I also used the same method on 409 stainless on an aftermarket exhaust system for a 396 Chevelle conv. I didn't want to use clamps for pipe to pipe connections so brazed them. Only used clamps for the pipe to muffler connections.
   / Welding exhaust pipe right off the manifold #10
409 is just barely stainless. Tig welded a lot of sensor fittings using 308 and backing gas with good results. Backing gas was a must.
BUSH HOG 3308R-2 LOT IDENTIFIER 106 (A53084)
BUSH HOG 3308R-2...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
WOODS RC60.20 LOT IDENTIFIER 81 (A53084)
WOODS RC60.20 LOT...
Toro Zero Turn (A50324)
Toro Zero Turn...
