Earning money with a 4' bucket?
   / Earning money with a 4' bucket? #1
stan33
There are some big projects going to start around here next year....a new airport and runway and a couple of large resorts one with a golf course.
Plus there may be smaller jobs around here as I know I have paid for a bobcat and driver in the past more than once.
I've looked into the state red tape and there is none for fel work. There is a 3 day course which is government recognised and I have seen adverts for jobs, where this ticket is asked for.
Also there is insurance and I would probably need a car trailer to move the tractor for more distant jobs.
But is there a need on construction sites for sub-contractors with smaller loaders? Would I need a backhoe and again would the size be of use?
This is a remote location with limited machinery available locally and bringing them in is very expensive.
Typically a machine plus driver (any machine from bobcat to JCB backhoe) including fuel and travel is around $110 per hour here ( a bit less in USD)
I didn't buy the tractor as a money venture but I am thinking there might be work to be had with it.
Do people agree or are there things I am not seeing here?
   / Earning money with a 4' bucket? #2
You will need to present your capabilities to the contractors that win the jobs.
Most have their own equipment and price the transportation into the bid.
Most big jobs leave a lot of "margin" for new equipment for the contractor. They don't often need some "maverick" operator unless you can provide a unique service as a subcontractor.
I guess as you didn't mention it, that the loader might be useful on a construction site.
There is a push from the local government to try to get the contractors to use locals wherever possible, to help stimulate the local economy (some of this is government funded).
Plus the fewer people the contractors have to bring in, the lower their accommodation costs, which means hotels.
   / Earning money with a 4' bucket? #4
I agree with CalG. It is unlikely that they will hire some guy unknown in the industry with a FEL on a consumer grade tractor (yes I am assuming that). You might be able to get a toe in the door and gradually build up a reputation and turn it into a going business. It'll take several years and many jobs though.
Harry K
Harry K
   / Earning money with a 4' bucket? #5
A lot depends on need and a lot depends on you. How good are you with a loader. Even if you get the job, if you are just an average Joe with a small tractor and front end loader you won't stay there long. I watch people here who think they can run a loader or hoe and all they do is make a mess. Can you keep a level grade? Can you level out a pile of dirt-gravel quickly and well? In other words you will have to be an operator not just a guy who can drive a tractor and run his loader up and down. Not trying to be hard but I don't want you to buy a trailer so you can get work and find you can't get it because you are not able to do it. Ed
   / Earning money with a 4' bucket? #6
Tractordata.com lists the MF240 as a 46 hp tractor and the FEL is listed at 60 inches wide. Am I missing something? I started with a 21 hp Kubota with a 48" bucket. My niche is local residents who can't find anyone to spread a load of dirt or crushed limestone to repair a driveway. I graduated to a 32 hp with 54" bucket as my projects became larger as I established myself. A 48" tiller for garden plots and a 60" grader blade (not a box blade) are my main tools. I did a few jobs with an auger but the smaller hp tractors do not seem to have the torque in the PTO to perform satisfactorily in the clay where I live. I traded the 32 hp with 1200 hours on it for a 39 hp and one frame size larger. Still doing work for local residents. I bid on a commercial project where the local county commissioner wanted to use local help. The contractor said I was twice as high as other bids. However he eventually used his own equipment. Two Cat backhoes, a large Cat wheel loader and at times 8 laborers. Three drivers and five guys with shovels on the ground. There is no way I was twice as high as his costs. He had over a million dollars in equipment whereas my partner and I had about 100K between us. Lesson learned. Do a good job, bid at a fair price and be easy to get along with. By the way I charge $60 an hour (US) for me and my equipment. $75 an hour when I have someone on the ground with a shovel and rake. I am not getting rich, however I have not had to go to an ATM in several years as many clients pay in cash. Check with the local, small contractors and talk to them about landscaping after construction is done. I have pulled the trigger on a three point backhoe to do some trenching with. You will want at least a 20 foot trailer. Any thing shorter and stuff will hang over the back end. After landscaping around a pad I generally advise the owner to lay sod to keep the dirt from washing away. I usually get that job as well. I go to the sod farm and buy in the field. I have a flat deck low boy car hauler 10,000 gvw which allows the fork lift to set the pallet of grass right on the trailer and makes for easy unloading as well. If you want to make some cash just get started. Another good implement is a three point brush cutter. Lots of people want their over grown property mowed. My niche is in the smaller projects. Leave airports to the the big boys (IMHO).
   / Earning money with a 4' bucket? #7
Agree with Ed. You will have to have a degree of skill. Lots of difference between "level" and just knocking down a pile of dirt. In my area if your tractor is not 4WD with an FEL you are just peeing in the wind. 2WD front end loaders just don't cut it.
The loader was built by a Massey dealer in another part of this state. They did this quite often in the 70's/80's. It's probably stronger than the Massey loader but the bucket is a bit narrower but probably a bit taller. Thanks for all the tips...good idea about the slasher....folks round here get fined if their grass is too long in the paddocks due to bush fire risk in the summer.
   / Earning money with a 4' bucket? #9
I agree with most of the others here. You will find more work doing residential. Brush mowing, grading drives, mulching, digging post holes, etc. Might require some new implements.
Large construction sites with proper equipment aint gonna want someone someone there with a SCUT spending all day doing something they can do in 15min.
Perhaps after they are done with heavy equip there "might" be a need for small equipment spreading seed, or towing a trailer with straw and blower, mulching, etc. But that would be about it IMO
In your experience, what are the pitfalls in doing this kind of work? ie jobs/customers/situations to avoid and typical problems encountered.
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2017 PETERBILT 579 DAYCAB (A53843)
2017 PETERBILT 579...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55218)
2003 International...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2014 Freightliner M2 106 24ft Box Truck (A52377)
2014 Freightliner...
